Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
2 commentaires:
I am terribly sorry but I am not sure what you are asking. It is possibly a language barrier, if English is not your first language, but that is no reason to not try and help you.
Are you referring to the battery? Or perhaps the charging port?
(Examples using a different device just to help communication.)
Example of a battery change: Remplacement de la batterie du Samsung Galaxy S10e
Example of a charging port change: Samsung Galaxy S22 USB-C Port and Charging Board Replacement
If it is something else, please clarify.
par Justin Castle
@erelectronics sounds like they mean the charge port
par daniel
