Aller au contenu principal
Lancé le 4 novembre 2017. Modèles A1868, A 1901. Disponible avec GSM ou CDMA /  64 ou 256 Go / argent et gris sidéral. (Se prononce "iPhone 10".)
1181 questions Voir tout
My screen is yellow and black. Help!
I needed a new battery as my old one was getting bloated. Bought a new battery here and changed it according to the instructions here. After attaching the screen back on. I’m getting visual of hello and black. I can’t see the home screen at all but it’s still functional.
I must have knicked something or it’s loose I’m not sure where to check. Any help is welcomed. Last case I can just buy a new screen and work from there. Thanks
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi Jeremy,
It is entirely possible the screen or one of its parts got damaged in the process, but the first thing to do is double-check your work. In particular the OLED connector is the one you want to pay attention to. It's this one.
So yeah, open the phone back up and disconnect the screen. Use a magnifying glass and a bright light to check the connector both on the cable and on the logic board. Look for any dirt, debris, broken or bent pins that might interfere with a good connection. Also examine the flex cable for any tears or extreme bends. Assuming it looks good, clean both sides of the connector with 90% or higher concentration of isopropyl (rubbing) alcohol, let it dry and reconnect it. Pay particular attention to the note on Step 20 of the Battery Replacement guide.
If nothing helps then it would be time to bite the bullet and replace the screen. I've been finding them cheaper and cheaper; nowadays you can get a soft OLED screen for $35 or less; the last one I bought was only $23 USD! I know it seems suspiciously cheap, but I installed it and it worked great and looked good. The only odd thing about it is that it doesn't come with the plastic camera mount where the earpiece speaker sits, but it's not difficult to pry the old one off the original screen to reuse it.
AAA+++For iPhone X XR XS XSMax LCD Display Touch Screen Replacement Touch Digeiter Assembly100% Tested+Tempered Film - AliExpress
Image Electronics Skills
Tutoriel
Reconnaître et débrancher les connecteurs
Difficulté :
Facile
8 minutes
Image iPhone X Batterie
Tutoriel
Remplacement de la batterie de l'iPhone X
Difficulté :
Modérée
1 - 2 hours
Indice 1
1 commentaire:
Will do thank you so much for the response! I’ll get back to you in a few days!
par
Ajouter une réponse
Jeremy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 24
