@edwoob22886 this is just an additional answer to the excellent answers provided by @claire17 and @vendredi
Like everybody else is already telling you, this is caused by the water that got spilled. Now, since you came to iFixit, you maybe looking for a more in depth answer about how to fix this. If you are up to it,
First thing to do is to disassemble your MBA and to remove the logic board. for that use this guide Then you need to check for any corrosion damage on the board. Post some good pictures of your logic board with your Question. That way we can see what you see and hopefully identity the area that was affected by the water. Use this guide for that.
Now it is time to clean the board. For that use this guide https://fr.ifixit.com/Tutoriel/R%C3%A9pa... and start at step 11. Clean the board a couple of times.
Once cleaned and after you have inspected all the other parts of your MBA , in particular the top case connectors (Keyboard etc.) reassemble your computer and re-evaluate. Of course, if there is any corrosion damage on the board or the keyboard/trackpad connector, that will have to get fixed first.
Until you have checked, cleaned and possibly repaired any damaged component, there is really no way to tell you what went wrong. After all, it could even be your keyboard that has shorted out, so you would most likely need a top case assembly. If this task appears to be to daunting to you, consider sending your computer to a repairer that has specialized in water repair. A lot of the more common repairers do not touch water damaged devices. That is because the chances to get them repaired is very low and not cost effective for them. It's a lot of work.
Do not let any of this discourage you. It's not easy, but not impossible. You have a large iFixit community here that is always willing to help you out. Remember:
Repair is War on Entropy!
Translation
@edwoob22886 ceci est juste une réponse supplémentaire aux excellentes réponses fournies par @claire17 et @vendredi
Comme tout le monde vous l'a déjà dit, cela est dû à l'eau qui a été renversée. Maintenant, puisque vous êtes venu sur iFixit, vous cherchez peut-être une réponse plus approfondie sur la façon de réparer ce problème. Si vous êtes prêt à le faire,
La première chose à faire est de démonter votre MBA et de retirer la carte logique. Pour cela, utilisez ce guide. Ensuite, il faut vérifier si la carte n'est pas endommagée par la corrosion. Postez quelques bonnes photos de votre carte logique avec votre question. De cette façon, nous pourrons voir ce que vous voyez et, espérons-le, identifier la zone qui a été affectée par l'eau. Utilisez ce guide pour cela.
Il est maintenant temps de nettoyer la carte. Pour cela, utilisez ce guide https://fr.ifixit.com/Tutoriel/R%C3%A9pa... et commencez à l'étape 11. Nettoyez la carte plusieurs fois.
Une fois nettoyée et après avoir inspecté toutes les autres parties de votre MBA, en particulier les connecteurs du boîtier supérieur (clavier, etc.), réassemblez votre ordinateur et réévaluez-le. Bien entendu, si la carte ou le connecteur du clavier/trackpad est endommagé par la corrosion, il faudra d'abord le réparer.
Tant que vous n'avez pas vérifié, nettoyé et éventuellement réparé tous les composants endommagés, il n'y a vraiment aucun moyen de savoir ce qui n'a pas fonctionné. Après tout, il se peut même que ce soit votre clavier qui ait subi un court-circuit, de sorte que vous aurez probablement besoin d'un assemblage du boîtier supérieur. Si cette tâche vous semble insurmontable, envisagez d'envoyer votre ordinateur à un réparateur spécialisé dans la réparation de l'eau. La plupart des réparateurs habituels ne s'occupent pas des appareils endommagés par l'eau. En effet, les chances de les faire réparer sont très faibles et ne sont pas rentables pour eux. C'est beaucoup de travail.
Ne vous laissez pas décourager. Ce n'est pas facile, mais ce n'est pas impossible. Vous pouvez compter sur la grande communauté iFixit qui est toujours prête à vous aider. N'oubliez pas :
La réparation, c'est la guerre contre l'entropie !
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
