Aller au contenu principal
Tutoriels de réparation et informations sur le démontage pour le MacBook Pro 14 pouces sorti en octobre 2021, équipé des SoC M1 Pro et M1 Max conçus par Apple. Modèle A2442.
20 questions Voir tout
Ordering a replacement screen in Canada
I was curious about my ability to use the calibration tools when ordering a replacement display in an unsupported country?
I'm in Canada, and I have a US<>CAN shipping service I use frequently to order US items that don't directly ship to Canada. So getting the display should be no issue. But I wasn't sure if I would have problems using the tools to calibrate the display.
Has anyone in Canada used the tools? People mention running them through a VPN, but I just wanted to confirm if anyone's actually done that successfully.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Good question! I think you'll need to use a VPN which has a US IP address to make sure it goes as intended.
If you do try to get it to work with a Canadian IP and it works let us know! Otherwise its the VPN.
Indice 0
1 commentaire:
Just deciding whether it's worth the risk (as the screen is a really pricey part).
My only worry is that even with a VPN, i will still get shut down on account of the serial number being potentially visible to Apple as a Canadian device.
I'm just trying to read around a bit on what the worst case scenario is if the tool doesn't work. If it's only losing true tone than I'm mostly OK with that - but if there are issues with local dimming zones, then that will make the screen essentially useless to me.
par
Ajouter une réponse
George K sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 61
