Washer does not rinse
I started a load of clothes the washer filled with water and washed the clothes when it got to the the rinse cycle is just stopped no noise. The water is still in there, I tried to restart the cycle and it did and stopped in the same place at Rinse.....
8 commentaires
I have a Kenmore maybe made by Whirlpool and have same problem. What was your fix?
par Jim
i have a maytag and the problem is , its spin but stop at rinse.
par adlihnalebehn
I have a washer that get to rinse cycle and stays there with a wired noises but the rinse don't do nothing so I have to turn it to spin , why rinse cycle don't work ? Anyone know
par Rick
Hi @homeless,
Post your comment as a new question in Ifixit, giving make and model number of washer and any other relevant information to add to the actual problem.
That way your question will not be overlooked because it is posted as a comment, in a question about a Kenmore 90 series washer., and you will hopefully get answers more relevant to your particular problem.
Have you tried different wash cycles i.e. Regular, Delicates, Permanent Press etc (if applicable in your washer) to see if it happens only in the 1 mode or all of them? Does the timer step normally through the wash and spin cycles but not through the rinse cycle or only at the start of the rinse cycle etc?
par jayeff
My whirlpool washer washes and drains but when it gets to the rinse cycle it stops and just sits there with no water in it. Can you tell me how to fix it.
par Lisa Williams
Voir 3 commentaires en plus
