Aller au contenu principal
« Retour à Toutes les histoires
Ipod classic gen 3
Andrew O'Brien -
iPod 3rd Generation
Image de l'histoire
  • Image n° 1
  • Image n° 2
  • Image n° 3
iPod 3rd Generation Battery Replacement
30 minutes
Moderate
Mon problème
my ipod would not charge, turn on, or hold a charge. Whenever it was plugged in, the iPod would display the apple logo then flash off. The battery was bad.
Ma solution
I recieved the battery replacement kit one day early, and got right to work. Popping apart the iPod was the hardest part of the whole repair, with not breaking the hard drive ribbon cable as a very close second. Removing the battery and placing the new battery was quite easy, and routing the cable so it would pop back together was easy enough. After replacing the battery, I was able to breathe new life into an otherwise fancy paperweight.
Mon conseil
be very careful popping apart the case, because the lock switch assembly and headphone jack can be ripped from the internal logic board and wreak havoc to that board. bottom first, then work around to the top. CAREFULLY.
Image iPod 3G Battery
iPod 3G Battery
$13.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 193
