Aller au contenu principal
« Retour à Toutes les histoires
Fan Replacement
ctjewett -
MacBook Air 11" Mid 2011
Image de l'histoire
MacBook Air 11" Mid 2011 Fan Replacement
15 minutes
Moderate
Mon problème
Old fan was making all sorts of noise. I didn't even realize my Mac had a fan for years until this fan started to go, and then it was obvious as a blue sky.
Ma solution
Overall, it was a pretty easy repair, but a tad trickier than a standard PC laptop due to the tight tolerances and incredibly small parts. If you can put the Mac in a shallow box so no screws get lost in the process, it'll probably help considerably.
Mon conseil
The only super tricky part was sliding the new fan's ribbon cable into the slot. I used the spudger and pushed on the only small crease I could find to slide it into the slot. I suggest powering it on while still apart to verify functionality, then power it off and finish stitching everything back together.
Image MacBook Air 11" (Mid 2011-Early 2015) Fan
$19.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 124
