Aller au contenu principal
« Retour à Toutes les histoires
Back in Business!
Ronald Mitchum -
iPhone 5c
Image de l'histoire
iPhone 5c Battery Replacement
10 minutes
Moderate
Mon problème
The battery that I bought from New Egg was crap
Ma solution
Went great, Great kit, everything included. Did it before with another kit which was not as good.
Mon conseil
If you do not take off the screen, just make sure it is supported at a bit less than 90 degrees, so you can use both hands. Small screws on the battery hold down, the magnetic drivers in the kit work very well. In the previous replacement I had trouble getting the OEM battery out, the tabs broke off, so just take a heat gun or hair dryer on low and carefully heat the underneath of the case a bit, if it feels hot it is too hot, heat only the battery side, the battery will start to give way using one of the kit tools, take a lot of time to do this maybe 10 minutes off and on. I work under a magnifying light.
Image iPhone 5c Battery
iPhone 5c Battery
$29.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 115
