Aller au contenu principal
« Retour à Toutes les histoires
Samsung Galaxy Note 3 - Charging Assembly Replacement
Angie Willmorth -
Image de l'histoire
Samsung Galaxy Note 3 Motherboard Replacement
15 minutes
Easy
Mon problème
The USB port was damaged after years of use
Ma solution
The repair was straight forward and went well.
Mon conseil
The link for the replacing the charging assembly is for removing the motherboard. Replacing the charging assembly does not require removal of the motherboard.
Here is what I did. Using the instructions for removing the mother board stop after step 6, "Removing the Back Chassis". Then you undo the antenna clip at the USB assembly side only, and disconnect the two cables on the USB assembly that connect it to the motherboard. Then as per your instructions in the tear down “Use spudger to remove the USB board with proper strength because the USB board is stuck with glue.”
Image Galaxy Note 3 (T-Mobile) Charging Assembly
$24.99
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 358
