Aller au contenu principal
« Retour à Toutes les histoires
Digitizer disaster
Ken Spires -
iPad Air Wi-Fi
Image de l'histoire
iPad Air Wi-Fi Front Panel Assembly Replacement
2 heures
Moderate
Mon problème
It was cheaper to fix than replace, plus I LOVE a challenge.
Ma solution
I was a little nervous. I have replaced several iPhone screens, but this was my first iPad. Clear a spot at a bench, spread out a darker colored (lint-free) fabric. I use dark so that tiny screws, etc. will stand out. Also, if you have access to an anti-static mat, that is better.
Mon conseil
If you are not using an anti-static mat, be sure anytime you let go of whatever you are working on, you ground yourself to the metal frame before proceeding. Do not rush, follow instructions, BE GENTLE! I used clear packing tape to keep the digitizer together while working with it. It also kept small shards from sticking out and cutting me. Use clear tape so you can still see the LED display. Be diligent when cleaning old glass and seal fragments. Be patient.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 21
Total : 122
