Aller au contenu principal
Pour réparer ensemble - Je crée un compte
ASUS D550MA-DS01 Keyboard Module Replacement
Ce dont vous avez besoin
  1. ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: étape 1, image 1 de 2 ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. ASUS D550MA-DS01 Keyboard Module Replacement: étape 2, image 1 de 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
    Demander à FixBot
  3. ASUS D550MA-DS01 Keyboard Module Replacement: étape 3, image 1 de 2 ASUS D550MA-DS01 Keyboard Module Replacement: étape 3, image 2 de 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    Demander à FixBot
  4. ASUS D550MA-DS01 Keyboard Module Replacement: étape 4, image 1 de 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
    Demander à FixBot
  5. ASUS D550MA-DS01 Keyboard Module Replacement: étape 5, image 1 de 1
    • Remove the fully disconnected keyboard module from the laptop.
    Demander à FixBot
4 autres ont terminé cette réparation.
redacted
Membre depuis le 09/15/15
566 Réputation
3 tutoriels rédigés
3 commentaires de tutoriel
Does anybody knows how to remove the keyboard from the keyboard module??I want to replace the keyboard not the whole piece
mfq1979 - Réponse Partager
where can I get a keyboard replacement
Kwame Mitchell - Réponse Partager
http://www.newegg.com
Replacement Keyboard N2840 s/n EBNOCX62041047D sold by, Alpha Vr Electronics, 860-755-2309 ext. 22831 $20.99
Eugene Bohrmann - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 57
Total : 2,814
