Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Anker SoundCore 2 Bluetooth Chip Replacement
Ce dont vous avez besoin
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: étape 1, image 1 de 2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: étape 1, image 2 de 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Demander à FixBot
      Ajouter un commentaire
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: étape 2, image 1 de 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: étape 2, image 2 de 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: étape 2, image 3 de 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      Demander à FixBot
    2. Anker SoundCore 2 Bluetooth Chip Replacement: étape 3, image 1 de 3 Anker SoundCore 2 Bluetooth Chip Replacement: étape 3, image 2 de 3 Anker SoundCore 2 Bluetooth Chip Replacement: étape 3, image 3 de 3
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      Demander à FixBot
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: étape 4, image 1 de 2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: étape 4, image 2 de 2
      • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
      • For help desoldering and soldering, follow this guide.
      Demander à FixBot
Carson Kiichle
Membre depuis le 01/14/21
498 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 63
Total : 3,006
