Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Anker SoundCore 2 Microphone Replacement
Ce dont vous avez besoin
    1. Anker SoundCore 2 Microphone Replacement, Front Panel: étape 1, image 1 de 2 Anker SoundCore 2 Microphone Replacement, Front Panel: étape 1, image 2 de 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Demander à FixBot
      Ajouter un commentaire
    1. Anker SoundCore 2 Microphone Replacement, Microphone: étape 2, image 1 de 3 Anker SoundCore 2 Microphone Replacement, Microphone: étape 2, image 2 de 3 Anker SoundCore 2 Microphone Replacement, Microphone: étape 2, image 3 de 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Flip up the speaker mount panel from the speaker housing case.
      Demander à FixBot
    2. Anker SoundCore 2 Microphone Replacement: étape 3, image 1 de 3 Anker SoundCore 2 Microphone Replacement: étape 3, image 2 de 3 Anker SoundCore 2 Microphone Replacement: étape 3, image 3 de 3
      • Disconnect the microphone wire from the motherboard.
      • Use a spudger to pry the microphone out of the speaker mount panel.
      • The microphone is held in place with glue, so you may need to re-glue the new microphone onto the speaker mount panel.
      Demander à FixBot
Tripp Lersch
Membre depuis le 01/14/21
411 Réputation
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 49
Total : 1,632
