Introduction
This guide will show you how to replace the button panel on the Anker Souncore Motion Boom Plus device. The button panel allows you to operate the speaker manual; this is where you can use the power, Bluetooth, and volume buttons. If any buttons are unresponsive, the device's button panel may need to be replaced.
Power off the device before continuing to tear it down. Ensure that you use the proper tools to prevent damage to any components on the device.
Ce dont vous avez besoin
Insert an opening tool into the seam between the speaker grille and the chassis.
Pry the tool around the top, bottom, and sides until the grille fully releases.
Remove the grille.
Remove all eight 7 mm Phillips screws securing the button panel to the top of the case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
