Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Anki Vector Capacitive Touch Sensor Replacement
Ce dont vous avez besoin
  1. Anki Vector  Capacitive Touch Sensor Replacement, Belts: étape 1, image 1 de 1
    • Raise Vector's arms above his head.
    Demander à FixBot
    Ajouter un commentaire
  2. Anki Vector  Capacitive Touch Sensor Replacement: étape 2, image 1 de 2 Anki Vector  Capacitive Touch Sensor Replacement: étape 2, image 2 de 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
    Demander à FixBot
  3. Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: étape 3, image 1 de 3 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: étape 3, image 2 de 3 Anki Vector  Capacitive Touch Sensor Replacement, LCD Facial Display: étape 3, image 3 de 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
    Demander à FixBot
  4. Anki Vector  Capacitive Touch Sensor Replacement: étape 4, image 1 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 4, image 2 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 4, image 3 de 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
    Demander à FixBot
  5. Anki Vector  Capacitive Touch Sensor Replacement: étape 5, image 1 de 2 Anki Vector  Capacitive Touch Sensor Replacement: étape 5, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
    Demander à FixBot
  6. Anki Vector  Capacitive Touch Sensor Replacement: étape 6, image 1 de 2 Anki Vector  Capacitive Touch Sensor Replacement: étape 6, image 2 de 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
    Demander à FixBot
  7. Anki Vector  Capacitive Touch Sensor Replacement: étape 7, image 1 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 7, image 2 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 7, image 3 de 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
    Demander à FixBot
  8. Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: étape 8, image 1 de 2 Anki Vector  Capacitive Touch Sensor Replacement, Capacitive Touch Sensor: étape 8, image 2 de 2
    • Using the Jimmy, insert the straight edge of the blade in recess groove in Vector's front wheel.
    • Slowly apply torque to the jimmy until the wheel cover pops off.
    • Repeat for the rear wheel.
    Demander à FixBot
  9. Anki Vector  Capacitive Touch Sensor Replacement: étape 9, image 1 de 2 Anki Vector  Capacitive Touch Sensor Replacement: étape 9, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew the two screws on the exposed wheels.
    • Once the screws are gone, remove the wheels from Vector's body.
    • Repeat this on the other side.
    Demander à FixBot
  10. Anki Vector  Capacitive Touch Sensor Replacement: étape 10, image 1 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 10, image 2 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 10, image 3 de 3
    • Gently remove the rear panel by griping it towards the top and pulling out and up.
    • Gently pull out the ribbon cable from the plug between the motherboard and the weight.
    Demander à FixBot
  11. Anki Vector  Capacitive Touch Sensor Replacement: étape 11, image 1 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 11, image 2 de 3 Anki Vector  Capacitive Touch Sensor Replacement: étape 11, image 3 de 3
    • Using a Phillips #0 screwdriver, unscrew the two screws located behind Vector's neck.
    • Lift the capacitive touch sensor assembly off of the body
    Demander à FixBot
4 autres ont terminé cette réparation.
Shay Takei
Membre depuis le 04/16/19
1 795 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S2-G6, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 46
Total : 1,984
