Introduction
If your Arlo Pro 2 camera is damaged, blurry, or not providing a video feed, follow this guide to replace the devices camera lens.
If the Arlo camera has fallen or been interfered with it may be not show a clear picture on the connected device.
Before using the guide, disconnect the Arlo Pro 2 camera from the device and power it off.
Ce dont vous avez besoin
Press the release button on the camera and gently pull apart the casing to open the device.
Remove the battery from inside the case.
Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
Seperate the daughterboards from the motherboard and camera casing.
Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
Carefully pull the motherboard apart from the camera casing.
Use a Philips #00 screwdriver to remove the four 4 mm screws on the back metal plate holding the daughterboards together.
Use a Philips #00 screwdriver to remove the two 5 mm screws on the back of the camera daughterboard to disconnect the camera piece from the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
