Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Arlo Pro 2 Camera Micro-USB Port Replacement
Ce dont vous avez besoin
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: étape 1, image 1 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: étape 1, image 2 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Motherboard: étape 1, image 3 de 3
      • Press the release button on the camera and gently pull apart the casing to open the device.
      • Remove the battery from inside the case.
      Demander à FixBot
      Ajouter un commentaire
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: étape 2, image 1 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 2, image 2 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 2, image 3 de 3
      • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
      • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
      Demander à FixBot
    3. Arlo Pro 2 Camera Micro-USB Port Replacement: étape 3, image 1 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 3, image 2 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 3, image 3 de 3
      • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
      • Seperate the daughterboards from the motherboard and camera casing.
      Demander à FixBot
    4. Arlo Pro 2 Camera Micro-USB Port Replacement: étape 4, image 1 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 4, image 2 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 4, image 3 de 3
      • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
      • Carefully pull the motherboard apart from the camera casing.
      Demander à FixBot
    5. Arlo Pro 2 Camera Micro-USB Port Replacement: étape 5, image 1 de 2 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 5, image 2 de 2
      • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
      Demander à FixBot
    1. Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: étape 6, image 1 de 2 Arlo Pro 2 Camera Micro-USB Port Replacement, Camera Micro-USB Port: étape 6, image 2 de 2
      • Thread the wires of the Micro-USB port through the casing.
      • Guide the wiring through the opening so that the wiring is solely in the battery cavity and not going through any part of the case.
      Demander à FixBot
    2. Arlo Pro 2 Camera Micro-USB Port Replacement: étape 7, image 1 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 7, image 2 de 3 Arlo Pro 2 Camera Micro-USB Port Replacement: étape 7, image 3 de 3
      • Use a Phillips #00 screwdriver to remove two 3 mm screws connecting the Micro-USB port to the camera casing.
      • Gently remove the Micro-USB port by pulling it away from the case.
      Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
Membre depuis le 03/26/25
493 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Botvin Spring 2025 Membre de l'équipe UMass Dartmouth, Team 2-2, Botvin Spring 2025
UMASSD-BOTVIN-S25S2G2
3 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Great guide, I was able to remove the Micro USB Charge Port and Cable from the arlo PRO 2 (Model: VMC4030P) without having to remove the System Board. However finding a replacement part is the tricky part. I stumbled across this guide after removing the cable hoping an iFixIt guide might have a link to a part source.
tech2life - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 54
Total : 393
