Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Contixo V8 Battery Replacement
Ce dont vous avez besoin
    1. Contixo V8 Battery Replacement, Battery: étape 1, image 1 de 1
      • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
      • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
      • Lift the face of the tablet.
      Demander à FixBot
      Ajouter un commentaire
    2. Contixo V8 Battery Replacement: étape 2, image 1 de 1
      • Use the spudger tool to separate the battery from metal screen frame; there will be a small strip of double-sided tape holding it in place. A blue iFixit opening tool would also work for this purpose.
      Demander à FixBot
    3. Contixo V8 Battery Replacement: étape 3, image 1 de 1
      Outil utilisé dans cette étape :
      Anti-Static Wrist Strap
      $7.95
      • Press the soldering tip to the 3 connection points to detach the motherboard and the battery. See this guide for information and tips on soldering and desoldering.
      • You will need to reattach these connection points when reassembling your device with the soldering iron. This guide will walk you through how to do that. Be sure to attach the positive and negative wires to the correct connections.
      • Exercise caution when desoldering the battery, especially if you've had issues with the device's power which could point to it being faulty. Consider using an anti-static wrist strap when working with the battery and its cables. See this guide for information on swollen batteries, another thing to look out for.
      • The battery is now disconnected and ready to be replaced.
      Demander à FixBot
phil_sc_03
Membre depuis le 09/08/23
231 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 44
Total : 1,172
