Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dymo LabelManager 280 Screen Replacement
Ce dont vous avez besoin
    1. Dymo LabelManager 280 Screen Replacement, Rear Case: étape 1, image 1 de 2 Dymo LabelManager 280 Screen Replacement, Rear Case: étape 1, image 2 de 2
      • Remove battery.
      • Remove the label cassette.
      Demander à FixBot
      Ajouter un commentaire
    2. Dymo LabelManager 280 Screen Replacement: étape 2, image 1 de 2 Dymo LabelManager 280 Screen Replacement: étape 2, image 2 de 2
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Demander à FixBot
    3. Dymo LabelManager 280 Screen Replacement: étape 3, image 1 de 2 Dymo LabelManager 280 Screen Replacement: étape 3, image 2 de 2
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Demander à FixBot
    1. Dymo LabelManager 280 Screen Replacement, Screen: étape 4, image 1 de 1
      • Further remove the 2 screws (1.2mm X 4mm Phillips #0 head).
      Demander à FixBot
    2. Dymo LabelManager 280 Screen Replacement: étape 5, image 1 de 2 Dymo LabelManager 280 Screen Replacement: étape 5, image 2 de 2
      • Detach the ribbon cable.
      Demander à FixBot
    3. Dymo LabelManager 280 Screen Replacement: étape 6, image 1 de 1
      • Remove the screen.
      Demander à FixBot
Steven Nguyen
Membre depuis le 02/08/16
431 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 6-5, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Hi, thak you for the tutorial, it seems pretty simple. Do you know where to find the LCD screen, or whats the specs, maybe I can find it at AliExpress.
Jacques Maltais - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 55
Total : 4,835
