Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Epson Powerlite 460 Lens Replacement
Ce dont vous avez besoin
    1. Epson Powerlite 460 Lens Replacement, Motherboard: étape 1, image 1 de 2 Epson Powerlite 460 Lens Replacement, Motherboard: étape 1, image 2 de 2
      • Orient the device so that the projection window is facing down and the bottom of the device is visible.
      • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Epson Powerlite 460 Lens Replacement: étape 2, image 1 de 3 Epson Powerlite 460 Lens Replacement: étape 2, image 2 de 3 Epson Powerlite 460 Lens Replacement: étape 2, image 3 de 3
      • Flip the device over so that the projection window is facing up.
      • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
      • Remove the air filter cover.
      Demander à FixBot
    3. Epson Powerlite 460 Lens Replacement: étape 3, image 1 de 2 Epson Powerlite 460 Lens Replacement: étape 3, image 2 de 2
      • Remove the two 13.3mm screws from the top cover above the air filter using a Phillips #2 screwdriver.
      • Remove one 13.3mm screw from above the connection panel using a Phillips #2 screwdriver.
      Demander à FixBot
    4. Epson Powerlite 460 Lens Replacement: étape 4, image 1 de 2 Epson Powerlite 460 Lens Replacement: étape 4, image 2 de 2
      • Remove the cover from the projector and set aside.
      • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
      Demander à FixBot
    5. Epson Powerlite 460 Lens Replacement: étape 5, image 1 de 3 Epson Powerlite 460 Lens Replacement: étape 5, image 2 de 3 Epson Powerlite 460 Lens Replacement: étape 5, image 3 de 3
      • Use the opening tool to disconnect eleven clip cables on the motherboard.
      • These will be the colorful cables connected with white plastic clips.
      • Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
      • To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
      Demander à FixBot
    6. Epson Powerlite 460 Lens Replacement: étape 6, image 1 de 1
      • Disconnect the clip cable from below the motherboard and behind the connection panel.
      Demander à FixBot
    7. Epson Powerlite 460 Lens Replacement: étape 7, image 1 de 3 Epson Powerlite 460 Lens Replacement: étape 7, image 2 de 3 Epson Powerlite 460 Lens Replacement: étape 7, image 3 de 3
      • Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
      • Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
      • Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
      Demander à FixBot
    8. Epson Powerlite 460 Lens Replacement: étape 8, image 1 de 1
      • Gently lift the motherboard out of the device.
      Demander à FixBot
    1. Epson Powerlite 460 Lens Replacement, Lens: étape 9, image 1 de 2 Epson Powerlite 460 Lens Replacement, Lens: étape 9, image 2 de 2
      • Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
      • Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
      Demander à FixBot
    2. Epson Powerlite 460 Lens Replacement: étape 10, image 1 de 2 Epson Powerlite 460 Lens Replacement: étape 10, image 2 de 2
      • Remove the two 13.3mm screws from the metal bracket surrounding the lens unit using a Phillips #0 screwdriver.
      • Remove the bracket.
      Demander à FixBot
    3. Epson Powerlite 460 Lens Replacement: étape 11, image 1 de 2 Epson Powerlite 460 Lens Replacement: étape 11, image 2 de 2
      • Remove the two 13.3mm screws from the lens cover using a Phillips #0 screwdriver.
      • Use your finger to release the clips on either side of the lens cover.
      • Lift the lens cover to remove it from the projector.
      Demander à FixBot
    4. Epson Powerlite 460 Lens Replacement: étape 12, image 1 de 2 Epson Powerlite 460 Lens Replacement: étape 12, image 2 de 2
      • Remove the five 9.4mm screws from the lens using a Phillips #0 screwdriver.
      • Lift the lens out of the unit.
      Demander à FixBot
Korinna Curry
Membre depuis le 04/06/22
268 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 17
Total : 443
