Aller au contenu principal
Framework Desktop Case Replacement
Ce dont vous avez besoin
  1. Framework Desktop Case Replacement, Power down your Desktop: étape 1, image 1 de 2 Framework Desktop Case Replacement, Power down your Desktop: étape 1, image 2 de 2
    • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
  2. Framework Desktop Case Replacement, Remove the Handle: étape 2, image 1 de 3 Framework Desktop Case Replacement, Remove the Handle: étape 2, image 2 de 3 Framework Desktop Case Replacement, Remove the Handle: étape 2, image 3 de 3
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
  3. Framework Desktop Case Replacement, Remove the Top Panel screws: étape 3, image 1 de 3 Framework Desktop Case Replacement, Remove the Top Panel screws: étape 3, image 2 de 3 Framework Desktop Case Replacement, Remove the Top Panel screws: étape 3, image 3 de 3
    • Use your finger to lift up the two D-rings on the Top Panel screws.
  4. Framework Desktop Case Replacement: étape 4, image 1 de 3 Framework Desktop Case Replacement: étape 4, image 2 de 3 Framework Desktop Case Replacement: étape 4, image 3 de 3
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
  5. Framework Desktop Case Replacement: étape 5, image 1 de 3 Framework Desktop Case Replacement: étape 5, image 2 de 3 Framework Desktop Case Replacement: étape 5, image 3 de 3
    • Repeat the same procedure for the other Top Panel screw.
  6. Framework Desktop Case Replacement, Remove the Top Panel: étape 6, image 1 de 3 Framework Desktop Case Replacement, Remove the Top Panel: étape 6, image 2 de 3 Framework Desktop Case Replacement, Remove the Top Panel: étape 6, image 3 de 3
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
  7. Framework Desktop Case Replacement, Remove the Left Panel: étape 7, image 1 de 3 Framework Desktop Case Replacement, Remove the Left Panel: étape 7, image 2 de 3 Framework Desktop Case Replacement, Remove the Left Panel: étape 7, image 3 de 3
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
  8. Framework Desktop Case Replacement, Lay down the Desktop: étape 8, image 1 de 2 Framework Desktop Case Replacement, Lay down the Desktop: étape 8, image 2 de 2
    • Lay down the Desktop on its side so the fan is facing upward.
  9. Framework Desktop Case Replacement, Disconnect the fan: étape 9, image 1 de 2 Framework Desktop Case Replacement, Disconnect the fan: étape 9, image 2 de 2
    • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
  10. Framework Desktop Case Replacement: étape 10, image 1 de 2 Framework Desktop Case Replacement: étape 10, image 2 de 2
    • If you aren't using an RGB fan, then skip this step.
    • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
  11. Framework Desktop Case Replacement, Remove the CPU fan screws: étape 11, image 1 de 2 Framework Desktop Case Replacement, Remove the CPU fan screws: étape 11, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
  12. Framework Desktop Case Replacement, Remove the fan duct: étape 12, image 1 de 2 Framework Desktop Case Replacement, Remove the fan duct: étape 12, image 2 de 2
    • Lift the fan duct off the fan and remove it.
  13. Framework Desktop Case Replacement, Remove the fan: étape 13, image 1 de 3 Framework Desktop Case Replacement, Remove the fan: étape 13, image 2 de 3 Framework Desktop Case Replacement, Remove the fan: étape 13, image 3 de 3
    • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
  14. Framework Desktop Case Replacement, Disconnect the top Expansion Card cable: étape 14, image 1 de 2 Framework Desktop Case Replacement, Disconnect the top Expansion Card cable: étape 14, image 2 de 2
    • Pull the top Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  15. Framework Desktop Case Replacement, Disconnect the main power cable: étape 15, image 1 de 2 Framework Desktop Case Replacement, Disconnect the main power cable: étape 15, image 2 de 2
    • While squeezing the clip on the main power cable, pull it straight up and out of its socket to disconnect it.
  16. Framework Desktop Case Replacement, Disconnect the CPU power cable: étape 16, image 1 de 2 Framework Desktop Case Replacement, Disconnect the CPU power cable: étape 16, image 2 de 2
    • While squeezing the clip on the CPU power cable, pull it straight up and out of its socket to disconnect it.
  17. Framework Desktop Case Replacement, Disconnect the bottom Expansion Card cable: étape 17, image 1 de 2 Framework Desktop Case Replacement, Disconnect the bottom Expansion Card cable: étape 17, image 2 de 2
    • Pull the bottom Expansion Card connector straight out of its socket in the Mainboard to disconnect it.
  18. Framework Desktop Case Replacement, Reposition the Desktop: étape 18, image 1 de 2 Framework Desktop Case Replacement, Reposition the Desktop: étape 18, image 2 de 2
    • Lift the Desktop so it stands upright on your work surface.
  19. Framework Desktop Case Replacement, Remove the Right Panel: étape 19, image 1 de 3 Framework Desktop Case Replacement, Remove the Right Panel: étape 19, image 2 de 3 Framework Desktop Case Replacement, Remove the Right Panel: étape 19, image 3 de 3
    • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
    • Remove the Right Panel.
  20. Framework Desktop Case Replacement, Remove the top plate screws: étape 20, image 1 de 3 Framework Desktop Case Replacement, Remove the top plate screws: étape 20, image 2 de 3 Framework Desktop Case Replacement, Remove the top plate screws: étape 20, image 3 de 3
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
  21. Framework Desktop Case Replacement, Remove the top plate: étape 21, image 1 de 2 Framework Desktop Case Replacement, Remove the top plate: étape 21, image 2 de 2
    • Lift the top plate off the Desktop and remove it.
  22. Framework Desktop Case Replacement, Reposition the Desktop: étape 22, image 1 de 2 Framework Desktop Case Replacement, Reposition the Desktop: étape 22, image 2 de 2
    • Lay the left side of the Desktop on your work surface so the underside of the Mainboard is facing upward.
  23. Framework Desktop Case Replacement, Remove the Wi-Fi Module screw: étape 23, image 1 de 2 Framework Desktop Case Replacement, Remove the Wi-Fi Module screw: étape 23, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  24. Framework Desktop Case Replacement, Remove the Wi-Fi module cover: étape 24, image 1 de 2 Framework Desktop Case Replacement, Remove the Wi-Fi module cover: étape 24, image 2 de 2
    • Use your fingers to slide the Wi-Fi module cover straight off the bottom of the module.
    • Remove the cover.
  25. Framework Desktop Case Replacement, Disconnect the Wi-Fi module: étape 25, image 1 de 3 Framework Desktop Case Replacement, Disconnect the Wi-Fi module: étape 25, image 2 de 3 Framework Desktop Case Replacement, Disconnect the Wi-Fi module: étape 25, image 3 de 3
    • The Wi-Fi module has two delicate coaxial cable connectors. Follow this step carefully to avoid damaging them.
    • Press and hold the Wi-Fi module down with your fingers.
    • Use your fingers to grip the white antenna cable, as close to the metal head as possible.
    • If you have angled tweezers, slide one arm of a pair of tweezers under the antenna connector, as close to the metal head as possible.
    • Gently lift the connector straight up to disconnect the white antenna cable.
    • Repeat the procedure with the black antenna cable.
  26. Framework Desktop Case Replacement, Remove the Wi-Fi module: étape 26, image 1 de 2 Framework Desktop Case Replacement, Remove the Wi-Fi module: étape 26, image 2 de 2
    • Grip the Wi-Fi module by its edges and pull it straight out of its socket.
    • Remove the Wi-Fi module.
  27. Framework Desktop Case Replacement, Reposition the Desktop: étape 27, image 1 de 2 Framework Desktop Case Replacement, Reposition the Desktop: étape 27, image 2 de 2
    • Rotate the Desktop onto its right side so the Mainboard is facing upward.
  28. Framework Desktop Case Replacement, Disconnect the power button: étape 28, image 1 de 2 Framework Desktop Case Replacement, Disconnect the power button: étape 28, image 2 de 2
    • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
  29. Framework Desktop Case Replacement, Remove the Mainboard screws: étape 29, image 1 de 2 Framework Desktop Case Replacement, Remove the Mainboard screws: étape 29, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws securing the Mainboard.
  30. Framework Desktop Case Replacement, Remove the Mainboard: étape 30, image 1 de 3 Framework Desktop Case Replacement, Remove the Mainboard: étape 30, image 2 de 3 Framework Desktop Case Replacement, Remove the Mainboard: étape 30, image 3 de 3
    • Grab the Mainboard by its heatsink and pull it towards the front of the Desktop to slide it out of the rear port cutout.
    • Slide the Mainboard towards the top of the Desktop to remove it from the chassis.
  31. Framework Desktop Case Replacement, Remove the rear plate screws: étape 31, image 1 de 3 Framework Desktop Case Replacement, Remove the rear plate screws: étape 31, image 2 de 3 Framework Desktop Case Replacement, Remove the rear plate screws: étape 31, image 3 de 3
    • Use your Framework Desktop Screwdriver to remove the three 5.9 mm‑long Phillips screws securing the power supply.
    • Optionally, you can remove the six 4.0 mm‑long screws securing the rear plate to make removing the power supply easier.
    • If you don't remove the rear plate screws, skip the next step.
  32. Framework Desktop Case Replacement, Remove the rear plate: étape 32, image 1 de 2 Framework Desktop Case Replacement, Remove the rear plate: étape 32, image 2 de 2
    • Pull the rear plate off the back of the Desktop and remove it.
  33. Framework Desktop Case Replacement, Remove the power supply screw: étape 33, image 1 de 2 Framework Desktop Case Replacement, Remove the power supply screw: étape 33, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the 4.0 mm‑long Phillips screw securing the power supply.
  34. Framework Desktop Case Replacement, Reposition the power supply: étape 34, image 1 de 3 Framework Desktop Case Replacement, Reposition the power supply: étape 34, image 2 de 3 Framework Desktop Case Replacement, Reposition the power supply: étape 34, image 3 de 3
    • Lift the power supply out of its slot and let it rest on the left side of the Desktop.
  35. Framework Desktop Case Replacement, Remove the power supply: étape 35, image 1 de 3 Framework Desktop Case Replacement, Remove the power supply: étape 35, image 2 de 3 Framework Desktop Case Replacement, Remove the power supply: étape 35, image 3 de 3
    • Push the right Expansion Card cable through the gap between the power supply and its duct.
    • The gap is very small and might require some force to thread the cable through.
    • Remove the power supply.
  36. Framework Desktop Case Replacement, Disassembly complete: étape 36, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
  37. Framework Desktop Case Replacement, Remove the Top Panel screws: étape 37, image 1 de 3 Framework Desktop Case Replacement, Remove the Top Panel screws: étape 37, image 2 de 3 Framework Desktop Case Replacement, Remove the Top Panel screws: étape 37, image 3 de 3
    • Your replacement case requires some disassembly before transferring the internals. The next 12 steps will show how to disassemble the case.
  38. Framework Desktop Case Replacement: étape 38, image 1 de 3 Framework Desktop Case Replacement: étape 38, image 2 de 3 Framework Desktop Case Replacement: étape 38, image 3 de 3
  39. Framework Desktop Case Replacement: étape 39, image 1 de 3 Framework Desktop Case Replacement: étape 39, image 2 de 3 Framework Desktop Case Replacement: étape 39, image 3 de 3
  40. Framework Desktop Case Replacement, Remove the Top Panel: étape 40, image 1 de 3 Framework Desktop Case Replacement, Remove the Top Panel: étape 40, image 2 de 3 Framework Desktop Case Replacement, Remove the Top Panel: étape 40, image 3 de 3
  41. Framework Desktop Case Replacement, Remove the Right Panel: étape 41, image 1 de 3 Framework Desktop Case Replacement, Remove the Right Panel: étape 41, image 2 de 3 Framework Desktop Case Replacement, Remove the Right Panel: étape 41, image 3 de 3
  42. Framework Desktop Case Replacement, Replace the Front Panel: étape 42, image 1 de 3 Framework Desktop Case Replacement, Replace the Front Panel: étape 42, image 2 de 3 Framework Desktop Case Replacement, Replace the Front Panel: étape 42, image 3 de 3
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
    • Follow this guide to transfer your Tiles to the new Front Panel or to install the old Front Panel.
  43. Framework Desktop Case Replacement, Remove the top plate screws: étape 43, image 1 de 3 Framework Desktop Case Replacement, Remove the top plate screws: étape 43, image 2 de 3 Framework Desktop Case Replacement, Remove the top plate screws: étape 43, image 3 de 3
  44. Framework Desktop Case Replacement, Remove the top plate: étape 44, image 1 de 2 Framework Desktop Case Replacement, Remove the top plate: étape 44, image 2 de 2
  45. Framework Desktop Case Replacement, Remove the Mainboard screws: étape 45, image 1 de 2 Framework Desktop Case Replacement, Remove the Mainboard screws: étape 45, image 2 de 2
    • Use your Framework Desktop Screwdriver to remove the four 8.2 mm‑long Phillips screws in the Mainboard screw posts.
  46. Framework Desktop Case Replacement, Remove the rear plate screws: étape 46, image 1 de 2 Framework Desktop Case Replacement, Remove the rear plate screws: étape 46, image 2 de 2
  47. Framework Desktop Case Replacement, Remove the rear plate: étape 47, image 1 de 2 Framework Desktop Case Replacement, Remove the rear plate: étape 47, image 2 de 2
  48. Framework Desktop Case Replacement, Remove the tape: étape 48, image 1 de 3 Framework Desktop Case Replacement, Remove the tape: étape 48, image 2 de 3 Framework Desktop Case Replacement, Remove the tape: étape 48, image 3 de 3
    • Peel off the tape covering the antenna cables.
  49. Framework Desktop Case Replacement, Insert the Expansion card cable: étape 49, image 1 de 3 Framework Desktop Case Replacement, Insert the Expansion card cable: étape 49, image 2 de 3 Framework Desktop Case Replacement, Insert the Expansion card cable: étape 49, image 3 de 3
    • Thread the right Expansion card cable through the gap between the power supply and its duct.
  50. Framework Desktop Case Replacement, Place the power supply: étape 50, image 1 de 2 Framework Desktop Case Replacement, Place the power supply: étape 50, image 2 de 2
    • Place the power supply into its slot in the bottom of the Desktop.
  51. Framework Desktop Case Replacement, Install the power supply screw: étape 51, image 1 de 2 Framework Desktop Case Replacement, Install the power supply screw: étape 51, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the 4.0 mm‑long Phillips screw securing the power supply.
  52. Framework Desktop Case Replacement, Place the rear plate: étape 52, image 1 de 2 Framework Desktop Case Replacement, Place the rear plate: étape 52, image 2 de 2
    • If you didn't remove the rear plate, skip this step.
    • Place the rear plate onto the back of the Desktop.
  53. Framework Desktop Case Replacement, Install the rear plate screws: étape 53, image 1 de 3 Framework Desktop Case Replacement, Install the rear plate screws: étape 53, image 2 de 3 Framework Desktop Case Replacement, Install the rear plate screws: étape 53, image 3 de 3
    • Use your Framework Desktop Screwdriver to install the three 5.9 mm‑long Phillips screws securing the power supply.
    • If you removed the rear plate, use your Framework Desktop Screwdriver to install the six 4.0 mm‑long screws securing the rear plate.
  54. Framework Desktop Case Replacement, Place the Mainboard: étape 54, image 1 de 3 Framework Desktop Case Replacement, Place the Mainboard: étape 54, image 2 de 3 Framework Desktop Case Replacement, Place the Mainboard: étape 54, image 3 de 3
    • Grab the Mainboard by its heatsink and slide it into the chassis.
    • Align the rear ports with its cutout and the screw posts with the screw holes on the Mainboard.
    • You'll feel the Mainboard rest onto the screw posts when it's aligned properly.
    • Make sure no cables are trapped underneath the Mainboard before continuing.
  55. Framework Desktop Case Replacement, Install the Mainboard screws: étape 55, image 1 de 2 Framework Desktop Case Replacement, Install the Mainboard screws: étape 55, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the four 8.2 mm‑long Phillips screws securing the Mainboard.
  56. Framework Desktop Case Replacement, Connect the power button: étape 56, image 1 de 2 Framework Desktop Case Replacement, Connect the power button: étape 56, image 2 de 2
    • Slide the power button cable over the nine-pronged connector on the Mainboard.
  57. Framework Desktop Case Replacement, Reposition the Desktop: étape 57, image 1 de 2 Framework Desktop Case Replacement, Reposition the Desktop: étape 57, image 2 de 2
    • Rotate the Desktop onto its left side so the underside of the Mainboard is facing upward.
  58. Framework Desktop Case Replacement, Install the Wi-Fi module: étape 58, image 1 de 2 Framework Desktop Case Replacement, Install the Wi-Fi module: étape 58, image 2 de 2
    • Hold the Wi-Fi module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the Wi-Fi module's gold contacts and notch with the socket on the Mainboard.
    • Insert the Wi-Fi module into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The Wi-Fi module fits into the socket in one orientation. If it doesn't fit, try flipping the module.
  59. Framework Desktop Case Replacement, Connect the Wi-Fi Module: étape 59, image 1 de 3 Framework Desktop Case Replacement, Connect the Wi-Fi Module: étape 59, image 2 de 3 Framework Desktop Case Replacement, Connect the Wi-Fi Module: étape 59, image 3 de 3
    • Hold the Wi-Fi module down with your fingers.
    • Position the black antenna cable connector over the left Wi-Fi module's coaxial socket.
    • Tweezers can help position the connector.
    • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
    • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
    • Repeat the procedure with the white antenna cable.
  60. Framework Desktop Case Replacement: étape 60, image 1 de 3 Framework Desktop Case Replacement: étape 60, image 2 de 3 Framework Desktop Case Replacement: étape 60, image 3 de 3
    • Hook the Wi-Fi bracket over the corner of the Wi-Fi module opposite the antenna cables.
    • Rotate the bracket over the Wi-Fi module, making sure the screw hole isn't being obstructed by the antenna cables.
  61. Framework Desktop Case Replacement, Install the Wi-Fi module screw: étape 61, image 1 de 2 Framework Desktop Case Replacement, Install the Wi-Fi module screw: étape 61, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the 7.0 mm‑long Phillips screw securing the Wi-Fi module.
  62. Framework Desktop Case Replacement, Reposition the Desktop: étape 62, image 1 de 2 Framework Desktop Case Replacement, Reposition the Desktop: étape 62, image 2 de 2
    • Rotate the Desktop so it sits upright on your work surface.
  63. Framework Desktop Case Replacement, Place the top plate: étape 63, image 1 de 2 Framework Desktop Case Replacement, Place the top plate: étape 63, image 2 de 2
    • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
  64. Framework Desktop Case Replacement: étape 64, image 1 de 2 Framework Desktop Case Replacement: étape 64, image 2 de 2
    • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
  65. Framework Desktop Case Replacement, Install the top plate screws: étape 65, image 1 de 3 Framework Desktop Case Replacement, Install the top plate screws: étape 65, image 2 de 3 Framework Desktop Case Replacement, Install the top plate screws: étape 65, image 3 de 3
    • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
  66. Framework Desktop Case Replacement, Install the Right Panel: étape 66, image 1 de 3 Framework Desktop Case Replacement, Install the Right Panel: étape 66, image 2 de 3 Framework Desktop Case Replacement, Install the Right Panel: étape 66, image 3 de 3
    • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Right Panel and the silver base.
    • Push the Right Panel towards the base of the computer to engage the clips.
  67. Framework Desktop Case Replacement, Reposition the Mainboard: étape 67, image 1 de 2 Framework Desktop Case Replacement, Reposition the Mainboard: étape 67, image 2 de 2
    • Lay the right side of the Desktop on your work surface so the Mainboard is facing upward.
  68. Framework Desktop Case Replacement, Connect the bottom Expansion Card cable: étape 68, image 1 de 2 Framework Desktop Case Replacement, Connect the bottom Expansion Card cable: étape 68, image 2 de 2
    • Slide the bottom Expansion Card cable into its socket on the Mainboard.
  69. Framework Desktop Case Replacement, Connect the CPU power cable: étape 69, image 1 de 2 Framework Desktop Case Replacement, Connect the CPU power cable: étape 69, image 2 de 2
    • Orient the CPU power supply cable so its clip is facing the heatsink.
    • Slide the cable into its socket on the Mainboard until you feel it click into place.
  70. Framework Desktop Case Replacement, Connect the main power cable: étape 70, image 1 de 2 Framework Desktop Case Replacement, Connect the main power cable: étape 70, image 2 de 2
    • Orient the main power supply cable so its clip is facing away from the heatsink.
  71. Framework Desktop Case Replacement, Connect the top Expansion Card cable: étape 71, image 1 de 2 Framework Desktop Case Replacement, Connect the top Expansion Card cable: étape 71, image 2 de 2
    • Slide the top Expansion Card cable into its socket on the Mainboard.
  72. Framework Desktop Case Replacement, Insert the fan: étape 72, image 1 de 3 Framework Desktop Case Replacement, Insert the fan: étape 72, image 2 de 3 Framework Desktop Case Replacement, Insert the fan: étape 72, image 3 de 3
    • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
    • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
    • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
  73. Framework Desktop Case Replacement: étape 73, image 1 de 3 Framework Desktop Case Replacement: étape 73, image 2 de 3 Framework Desktop Case Replacement: étape 73, image 3 de 3
    • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
    • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
  74. Framework Desktop Case Replacement, Insert the fan duct: étape 74, image 1 de 2 Framework Desktop Case Replacement, Insert the fan duct: étape 74, image 2 de 2
    • Lay the fan duct on top of the fan with the lip facing upward.
    • Align the screw holes on the fan duct with the ones on the fan.
  75. Framework Desktop Case Replacement, Install the fan screws: étape 75, image 1 de 2 Framework Desktop Case Replacement, Install the fan screws: étape 75, image 2 de 2
    • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long screws securing the fan and fan duct.
  76. Framework Desktop Case Replacement, Connect the fan: étape 76, image 1 de 2 Framework Desktop Case Replacement, Connect the fan: étape 76, image 2 de 2
    • Orient the main fan cable so its two vertical lines are facing you.
    • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
  77. Framework Desktop Case Replacement, Connect the RGB cable: étape 77, image 1 de 3 Framework Desktop Case Replacement, Connect the RGB cable: étape 77, image 2 de 3 Framework Desktop Case Replacement, Connect the RGB cable: étape 77, image 3 de 3
    • Orient the RGB cable so the arrow is on the right side of the connector.
    • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
  78. Framework Desktop Case Replacement, Install the Left Panel: étape 78, image 1 de 3 Framework Desktop Case Replacement, Install the Left Panel: étape 78, image 2 de 3 Framework Desktop Case Replacement, Install the Left Panel: étape 78, image 3 de 3
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
  79. Framework Desktop Case Replacement, Install the Top Panel: étape 79, image 1 de 3 Framework Desktop Case Replacement, Install the Top Panel: étape 79, image 2 de 3 Framework Desktop Case Replacement, Install the Top Panel: étape 79, image 3 de 3
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
  80. Framework Desktop Case Replacement: étape 80, image 1 de 2 Framework Desktop Case Replacement: étape 80, image 2 de 2
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
  81. Framework Desktop Case Replacement, Install the Handle: étape 81, image 1 de 2 Framework Desktop Case Replacement, Install the Handle: étape 81, image 2 de 2
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
  82. Framework Desktop Case Replacement, Install the top panel screws: étape 82, image 1 de 3 Framework Desktop Case Replacement, Install the top panel screws: étape 82, image 2 de 3 Framework Desktop Case Replacement, Install the top panel screws: étape 82, image 3 de 3
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
  83. Framework Desktop Case Replacement: étape 83, image 1 de 3 Framework Desktop Case Replacement: étape 83, image 2 de 3 Framework Desktop Case Replacement: étape 83, image 3 de 3
    • Repeat the same procedure for the other top panel screw.
  84. Framework Desktop Case Replacement: étape 84, image 1 de 3 Framework Desktop Case Replacement: étape 84, image 2 de 3 Framework Desktop Case Replacement: étape 84, image 3 de 3
    • Use your finger to close the two D-rings on the top panel screws.
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
212 689 Réputation
1 039 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 78
Total : 78
