Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Garmin Edge 530 Back Cover Replacement
Ce dont vous avez besoin
  1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: étape 1, image 1 de 1
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Garmin Edge 530 Back Cover  Replacement: étape 2, image 1 de 3 Garmin Edge 530 Back Cover  Replacement: étape 2, image 2 de 3 Garmin Edge 530 Back Cover  Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
    Demander à FixBot
  3. Garmin Edge 530 Back Cover  Replacement: étape 3, image 1 de 3 Garmin Edge 530 Back Cover  Replacement: étape 3, image 2 de 3 Garmin Edge 530 Back Cover  Replacement: étape 3, image 3 de 3
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
    Demander à FixBot
  4. Garmin Edge 530 Back Cover  Replacement: étape 4, image 1 de 1
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
    Demander à FixBot
  5. Garmin Edge 530 Back Cover  Replacement, Motherboard: étape 5, image 1 de 2 Garmin Edge 530 Back Cover  Replacement, Motherboard: étape 5, image 2 de 2
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
    Demander à FixBot
  6. Garmin Edge 530 Back Cover  Replacement: étape 6, image 1 de 1
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
    Demander à FixBot
  7. Garmin Edge 530 Back Cover  Replacement: étape 7, image 1 de 2 Garmin Edge 530 Back Cover  Replacement: étape 7, image 2 de 2
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
    Demander à FixBot
  8. Garmin Edge 530 Back Cover  Replacement: étape 8, image 1 de 3 Garmin Edge 530 Back Cover  Replacement: étape 8, image 2 de 3 Garmin Edge 530 Back Cover  Replacement: étape 8, image 3 de 3
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
    Demander à FixBot
  9. Garmin Edge 530 Back Cover  Replacement, Back Cover: étape 9, image 1 de 1
    • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
    • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
    Demander à FixBot
2 autres ont terminé cette réparation.
Lainey Merriwether
Membre depuis le 02/22/22
644 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 2-1, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 membres
23 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 38
30 derniers jours : 194
Total : 5,953
