Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Garmin Vivoactive Display Unit Replacement
Ce dont vous avez besoin
    1. Garmin Vivoactive Display Unit Replacement, Wristband: étape 1, image 1 de 1
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      Demander à FixBot
      Ajouter un commentaire
    2. Garmin Vivoactive Display Unit Replacement: étape 2, image 1 de 2 Garmin Vivoactive Display Unit Replacement: étape 2, image 2 de 2
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      Demander à FixBot
    1. Garmin Vivoactive Display Unit Replacement, Display Unit: étape 3, image 1 de 1
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      Demander à FixBot
    2. Garmin Vivoactive Display Unit Replacement: étape 4, image 1 de 2 Garmin Vivoactive Display Unit Replacement: étape 4, image 2 de 2
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      Demander à FixBot
    3. Garmin Vivoactive Display Unit Replacement: étape 5, image 1 de 1
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      Demander à FixBot
    4. Garmin Vivoactive Display Unit Replacement: étape 6, image 1 de 1
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      Demander à FixBot
    5. Garmin Vivoactive Display Unit Replacement: étape 7, image 1 de 1
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      Demander à FixBot
    6. Garmin Vivoactive Display Unit Replacement: étape 8, image 1 de 1
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      Demander à FixBot
16 autres ont terminé cette réparation.
Katie Paswaters
Membre depuis le 10/01/15
532 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-21, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 membres
25 tutoriels rédigés
40 commentaires de tutoriel
Does anyone knows where can I buy a vivoactive display?
dragomariano - Réponse Partager
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - Réponse Partager
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - Réponse Partager
Any links found for replacement screen?
dskggray - Réponse Partager
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 33
30 derniers jours : 140
Total : 105,336
