Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Garmin inReach Explorer Plus LCD Screen Replacement
Ce dont vous avez besoin
    1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: étape 1, image 1 de 1
      • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
      Demander à FixBot
      Ajouter un commentaire
    2. Garmin inReach Explorer Plus LCD Screen Replacement: étape 2, image 1 de 1
      • Remove the back cover.
      Demander à FixBot
    3. Garmin inReach Explorer Plus LCD Screen Replacement: étape 3, image 1 de 2 Garmin inReach Explorer Plus LCD Screen Replacement: étape 3, image 2 de 2
      • Gently grasp the battery wire and disconnect it from the device.
      • Remove the battery from the device.
      Demander à FixBot
    1. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: étape 4, image 1 de 2 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: étape 4, image 2 de 2
      • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
      Demander à FixBot
    2. Garmin inReach Explorer Plus LCD Screen Replacement: étape 5, image 1 de 2 Garmin inReach Explorer Plus LCD Screen Replacement: étape 5, image 2 de 2
      • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
      • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
      Demander à FixBot
    3. Garmin inReach Explorer Plus LCD Screen Replacement: étape 6, image 1 de 2 Garmin inReach Explorer Plus LCD Screen Replacement: étape 6, image 2 de 2
      • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
      Demander à FixBot
    4. Garmin inReach Explorer Plus LCD Screen Replacement: étape 7, image 1 de 3 Garmin inReach Explorer Plus LCD Screen Replacement: étape 7, image 2 de 3 Garmin inReach Explorer Plus LCD Screen Replacement: étape 7, image 3 de 3
      • Gently lift the motherboard up and out of the device.
      Demander à FixBot
    1. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: étape 8, image 1 de 2 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: étape 8, image 2 de 2
      • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
      Demander à FixBot
    2. Garmin inReach Explorer Plus LCD Screen Replacement: étape 9, image 1 de 3 Garmin inReach Explorer Plus LCD Screen Replacement: étape 9, image 2 de 3 Garmin inReach Explorer Plus LCD Screen Replacement: étape 9, image 3 de 3
      • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
      Demander à FixBot
Sean Kelley
Membre depuis le 09/28/21
387 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 5-4, Hunter Fall 2021 Membre de l'équipe Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 membres
15 tutoriels rédigés
3 commentaires de tutoriel
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Réponse Partager
Ditto - where can we get a screen??
Ben Wallbank - Réponse Partager
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 43
Total : 1,758
