Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP 15-R011DX Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP 15-R011DX Cooling Fan Replacement, Battery: étape 1, image 1 de 2 HP 15-R011DX Cooling Fan Replacement, Battery: étape 1, image 2 de 2
    • Slide the lock mechanism on the left side of the laptop to the right.
    Demander à FixBot
    Ajouter un commentaire
  2. HP 15-R011DX Cooling Fan Replacement: étape 2, image 1 de 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
    Demander à FixBot
  3. HP 15-R011DX Cooling Fan Replacement, How to Access the Internal Components of an HP 15-R011DX: étape 3, image 1 de 2 HP 15-R011DX Cooling Fan Replacement, How to Access the Internal Components of an HP 15-R011DX: étape 3, image 2 de 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    Demander à FixBot
  4. HP 15-R011DX Cooling Fan Replacement: étape 4, image 1 de 2 HP 15-R011DX Cooling Fan Replacement: étape 4, image 2 de 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    Demander à FixBot
  5. HP 15-R011DX Cooling Fan Replacement: étape 5, image 1 de 2 HP 15-R011DX Cooling Fan Replacement: étape 5, image 2 de 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    Demander à FixBot
  6. HP 15-R011DX Cooling Fan Replacement: étape 6, image 1 de 3 HP 15-R011DX Cooling Fan Replacement: étape 6, image 2 de 3 HP 15-R011DX Cooling Fan Replacement: étape 6, image 3 de 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
    Demander à FixBot
  7. HP 15-R011DX Cooling Fan Replacement: étape 7, image 1 de 2 HP 15-R011DX Cooling Fan Replacement: étape 7, image 2 de 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
    Demander à FixBot
  8. HP 15-R011DX Cooling Fan Replacement, Hard Drive: étape 8, image 1 de 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
    Demander à FixBot
  9. HP 15-R011DX Cooling Fan Replacement: étape 9, image 1 de 2 HP 15-R011DX Cooling Fan Replacement: étape 9, image 2 de 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
    Demander à FixBot
  10. HP 15-R011DX Cooling Fan Replacement: étape 10, image 1 de 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
    Demander à FixBot
  11. HP 15-R011DX Cooling Fan Replacement, Motherboard: étape 11, image 1 de 2 HP 15-R011DX Cooling Fan Replacement, Motherboard: étape 11, image 2 de 2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
    Demander à FixBot
  12. HP 15-R011DX Cooling Fan Replacement: étape 12, image 1 de 1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
    Demander à FixBot
  13. HP 15-R011DX Cooling Fan Replacement: étape 13, image 1 de 1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
    Demander à FixBot
  14. HP 15-R011DX Cooling Fan Replacement: étape 14, image 1 de 1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
    Demander à FixBot
  15. HP 15-R011DX Cooling Fan Replacement: étape 15, image 1 de 1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
    Demander à FixBot
  16. HP 15-R011DX Cooling Fan Replacement, Cooling Fan: étape 16, image 1 de 1
    • The cooling fan assembly is located on the underside of the motherboard.
    • Using a Phillips #1 screwdriver, remove the three 5mm screws that secure the cooling fan assembly to the motherboard.
    Demander à FixBot
  17. HP 15-R011DX Cooling Fan Replacement: étape 17, image 1 de 1
    • Separate the cooling fan assembly from the motherboard and proceed to use the canned air to clean the inner pieces of the fan.
    • You can now clean the inner parts of the fan assembly or replace with a new assembly.
    Demander à FixBot
  18. HP 15-R011DX Cooling Fan Replacement: étape 18, image 1 de 1
    • Before reconnecting the cooling fan assembly, make sure to properly apply thermal paste and touch the two connectors together when reassembling your laptop.
    Demander à FixBot
Joshua Brockman
Membre depuis le 03/25/19
368 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S2G4
3 membres
6 tutoriels rédigés
1 commentaire de tutoriel
It appears as though the jfan1 connection on the motherboard doesn’t have a plastic connector. I’ve bought a fan for this laptop to solve some overheating issues, but I can’t find anywhere to plug it in (I’m assuming that on similar models, the jfan1 connection would be the one to use). Is there any way that I can somehow plug my fan into this motherboard?
Brandon Peterson - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 1,499
