Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP ProBook 640 G2 RAM Replacement
Ce dont vous avez besoin
    1. HP ProBook 640 G2 RAM Replacement, Battery: étape 1, image 1 de 1
      • Flip the laptop so the bottom is facing up.
      • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
      • Use a Torx T9 screwdriver to remove the single 6 mm screw.
      Demander à FixBot
      Ajouter un commentaire
    2. HP ProBook 640 G2 RAM Replacement: étape 2, image 1 de 1
      • Use a plastic opening tool to carefully pry the bottom case.
      • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
      • Remove the bottom cover.
      Demander à FixBot
    3. HP ProBook 640 G2 RAM Replacement: étape 3, image 1 de 3 HP ProBook 640 G2 RAM Replacement: étape 3, image 2 de 3 HP ProBook 640 G2 RAM Replacement: étape 3, image 3 de 3
      • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
      • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
      Demander à FixBot
    1. HP ProBook 640 G2 RAM Replacement, Hard Drive: étape 4, image 1 de 1
      • Loosen the four JIS J1 captive screws on the hard drive tray.
      • Use the black tab on the hard drive tray and pull it toward the bottom of the laptop to remove the drive.
      Demander à FixBot
    2. HP ProBook 640 G2 RAM Replacement: étape 5, image 1 de 3 HP ProBook 640 G2 RAM Replacement: étape 5, image 2 de 3 HP ProBook 640 G2 RAM Replacement: étape 5, image 3 de 3
      • Use the JIS J1 screwdriver to remove the four 3.0 mm screws on the sides of the hard drive tray—two from each side.
      • Remove the old hard drive from the tray.
      Demander à FixBot
    1. HP ProBook 640 G2 RAM Replacement, RAM: étape 6, image 1 de 1
      • Pull the disc drive out and set it aside.
      Demander à FixBot
    2. HP ProBook 640 G2 RAM Replacement: étape 7, image 1 de 2 HP ProBook 640 G2 RAM Replacement: étape 7, image 2 de 2
      • Slide a thin spudger or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the Wireless WLAN card.
      • Pull straight up on the black tab to disconnect the display cable.
      Demander à FixBot
    3. HP ProBook 640 G2 RAM Replacement: étape 8, image 1 de 3 HP ProBook 640 G2 RAM Replacement: étape 8, image 2 de 3 HP ProBook 640 G2 RAM Replacement: étape 8, image 3 de 3
      • Use a JIS J1 screwdriver to remove the two 5 mm silver screws securing the hinge covers.
      • Turn the laptop over and open the top cover.
      • Use an opening tool to gently pry the plastic hinge covers off both hinges.
      • Lift the keyboard and pull it gently toward you to remove it from the laptop.
      Demander à FixBot
    4. HP ProBook 640 G2 RAM Replacement: étape 9, image 1 de 3 HP ProBook 640 G2 RAM Replacement: étape 9, image 2 de 3 HP ProBook 640 G2 RAM Replacement: étape 9, image 3 de 3
      • Turn the keyboard assembly over so the motherboard is facing up.
      • Gently pull the metal retaining clips away from the RAM module.
      • The RAM module will pop up at an angle.
      • Pull the RAM card out of its slot and replace with a new one.
      • When replacing the RAM, slide it in at the same angle it was removed, making sure the metal teeth are aligned with the slot. Push down until it snaps into place between the metal arms.
      Demander à FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Daniel Garcia
Membre depuis le 09/12/25
196 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 47
Total : 235
