Aller au contenu principal
Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet
  1. Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet, Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet: étape 1, image 1 de 1
    • Éteignez l'ordinateur.
    • Si vous installez MacOS sur un nouveau lecteur avec la fonction de Récupération Internet, vous pouvez sautez cette étape.
    I thought this guide is for a completely new SSD, but in this example MacOS appears to already be running. Is the target SSD connected internally via SATA or is this guide for a USB based second SSD that will also run the OS?
    In the latter case, is the intent to run internet recovery on the new SSD and then open the machine up and connect it directly, replacing the old disk?
    orun bhuiyan - Réponse
    Sorry for the confusion, Orun! The new SSD guide shares a few steps with the general “boot to internet recovery mode” guide. If you’re installing MacOS to a new drive, you can skip this step. :)
    Taylor Dixon - Réponse
    Just to clarify, I have a late 2009 MacBook 6,1 running El Capitan and will be upgrading to a new SSD. Will Internet recovery work with this computer? The article states “after 2009”. Also I want to upgrade to High Sierra at the same time is there an option to select which OS or how does it decide?
    nathan davis - Réponse
    My current hard drive won’t read. I don’t care about saving anything on the computer at all and had planned on starting fresh. Can i just install the drive then do internet recovery mode or do i still have to have a backup usb with the os preinstaled?
    J H - Réponse
    Hi all,
    I recently purchased a Mac mini so that I could have iMessages on my Android phone. It was petty and so that my lesser than iPhone user people could stop complaining about the lack of blue messages.
    I ended up updating from the OEM hard drive to an SSD. I obtained a copy of Yosemite from the link below and installed an update to make sure it worked on the original drive.
    I had trouble with my Bluetooth keyboard so instead of going through all of that, I ran the installer again but selected my new drive and install the iOS onto the external drive without any issue. I then installed the SSD and it is working so far. Knocking on wood.
    Hope this is helpful and I haven't done anything wrong or caused anyone any issues.
    nick peloquin - Réponse
  2. Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet: étape 2, image 1 de 1
    • Une fois que l'ordinateur est complètement éteint, appuyez sur le bouton de marche, puis appuyez et maintenez immédiatement la combinaison de touches cmd + option + R.
    Does this option still work if using a Bluetooth keyboard?
    Chad Neumann - Réponse
    Chad, this option should still work if using a bluetooth keyboard. If you’ve paired the keyboard to the computer already, then it should connect quickly enough to register the keypresses. That said, it’s definitely less reliable than using a wired keyboard! And every bluetooth keyboard is different—one might work, and another might not. Good luck!
    Taylor Dixon -
    In my case, the SSD was completely new, and the only way I got internet recovery to work was to press Cmd+Opt+Shift+R, which installs the macOS version which came with my Mac (a Late 2012 21.5’’ iMac).
    Adrià - Réponse
    If you have a PC/Windows keyboard plugged in, then use Window+Alt+R for youngest compatible Mac-OS download.
    Ian Kjos - Réponse
    Thanks for the tips! The BT keyboard didn’t work so I used a handy Windows one.
    lucas -
    MacBook 2009 A1342 DOES NOT WORK, it always shows the ‘folder’ with a ? inside and there is nothing i can do. +, i already bought a copy of Lion 10.7 on app store but cant access it either HELP PLEASE ;-)
    Simon Saint-Pierre - Réponse
    Mine shows the same thing a folder with a ?, I couldn’t copy my hard drive as it crashed and the computer wouldn’t boot up. Now I’m starting with a brand new ssd I need to know how to or what to do.
    sweetbrandigirl2004 -
    On my MBP mid-2012, the Cmd+Opt+Shift+R worked for me too with a brand new SSD. Thx Adria!
    cat. - Réponse
    Oui pour moi aussi, avec mon MBP 13" mi 2012...
    Mickael Cambray -
    I have the A1224 and i can’t get to that back screen, I’ve tried com+opt+R and also opt+com+shift+R. It just go straight to log in screen. Any ideas that might help me get there?
    Art - Réponse
    I have MacBook A1280, I have tried all the keys combination but none is working. Keyboard perfectly working on pc but can't access Mac os partition.
    Michael Deborn - Réponse
    For me, press together button to turn on + option worked
    Ana Beatriz - Réponse
  3. Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet: étape 3, image 1 de 2 Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet: étape 3, image 2 de 2
    • Quand l'animation du globe tournant apparaît, vous pouvez relâcher les touches.
    • Le globe tournera pendant que la récupération Internet démarre. Si vous n'utilisez pas une connexion internet filaire, un message choisissez un réseau apparaîtra. Utilisez ce menu pour connecter votre ordinateur à un réseau Wi-Fi.
    when i want to input wifi password the keyboard is not working
    pika - Réponse
    Mine just gets stuck at WiFi connection…
    Kelly Cairns - Réponse
    Hi.
    In this step choosing the network I can't type my password to get my connexion.
    It shows me locked.
    Thanks
    Francisco
    Francisco Hernandez - Réponse
    Hi,
    In this step after connecting to WIFI it will be there forever no progress. If I click on another network it’s getting error’ed out with a globe and exclamation mark in it and error is “apple.com/support -1005 F”.
    Please assist me with some information on how to overcome this phase.
    Raghu.
    raghuvaran45.rv - Réponse
    Hi
    did you fixed it?
    i had same problume can you help me
    thank you
    vazisda -
    -3511 F Eror , whats does it means?
    Shuhrat Safarov - Réponse
    Mine is stuck flashing a folder with a question mark on it. Now what?
    lauren borkowski - Réponse
    cant get passed folder with ? mark inside PLS HELPà
    Even if your keyboard is AZERTY, write your password as using a QWERTY one. Just did it now.
    You're welcome ;)
    Nicolas Vaché - Réponse
    thank you sooooo much
    Geraldine Portal -
    I can’t get passed this… entered WiFi password and it just spins forever trying to login…
    Tom Baker - Réponse
    Same to me… did you fix it?
    Fritz Denner -
    Cela ne se connecte pas alors que le code est bon, comment faire ???
    coraline.mauna - Réponse
    Bonjour, je rentre mon mot de passe wifi, mais cela me refuse l’accès ?
    Ebrard Alexis - Réponse
    faite attention si vous êtes français ou autre et que votre clavier est en azerty, car moi j’ai finalement compris que dans le ordi c’était en qwerty voilà pourquoi il n’acceptait pas le bon mot de passe
    Marine Leclaire - Réponse
    After connecting to the network, globe keeps spinning, no progress bar appears underneath. Please advice how to proceed. Thanks
    miguelcruden - Réponse
    After inputting the WiFi password it gets stuck on the revolving globe showing 24:00 for ever. What might be the problem and how to fix this issue? please help!
    Srinivasa Rao Buddha - Réponse
    Solution: You need to set your DNS-server to 8.8.8.8 at your router.
    Pavel Veter - Réponse
    If you are in Malaysia and using Time Internet, this will not work. I used my mobile phone (Maxis) and a hotspot to get around the problem. Not sure if its the way the router is configured with my Time connection.
    james_abela - Réponse
    Indeed. Cannot get past Time internet and need to use the hotspot. Thank you very much james_abela.
    Y MY -
    A solution for me when stuck on entering wifi password and nothing happening was instead tether to my phone, i.e. mobile hotspot and that fixed it
    Lorenzo Monsif - Réponse
    I put the wifi and then it gets me stuck on the password part, I’m unsure if I type my devices password or my wifi password
    Olivia - Réponse
    You need to act as if you have an US keyboard with the order QWERTY and not QWERTZ that also fixed my issue
    ay luna -
    Another issue I’m having is that whenever it finishes to load my computer turns off and then I’m back on the globe screen. I really need help.
    Olivia - Réponse
    So no answer for somebody with the same problem of flashing folder with question mark? I have a MBP 2010, upgraded to 1TB Crucial SSD. Opt- CMD- R only gives me flashing folder with question mark. Come on Crucial , help out. Thanks!
    BBfreak 8 - Réponse
    I wrote the good password in the US keyboard. But it’s still loading how can it works? I only see something charging without any progress…
    Can someone help me ?
    manon - Réponse
    The typical problem when you get a flashing folder with a question mark on the screen is a problem with the hard drive. If you have changed the drive for a new one it might not be compatible or poorly seated, or you did not start internet recovery correctly/in time. If you have not changed your drive and your Mac suddenly have gotten this error, the hard drive is most likely defective and needs to be replaced, in my experience. @bbfreak8
    Roger_L - Réponse
    Nel momento in cui inserisco la mia password, la rotella dell’attesa comincia a girare ma non fa niente per ore. Ho provato diverse volte ad accenderlo con lo stesso procedimento e non fa niente. Se cambio password me la dà errata. Come posso risolvere?
    Francesco - Réponse
    I am not able to type the password for wifi.
    Please help
    praphul singh - Réponse
    As with other comments here, I'm on the screen to select my network, and the roadblock is the password. I put in the password for the network, gets bounced back. I try my password for the Mac itself, gets bounced back. Apple ID, gets bounced back. It's not specific as to what password it's looking for, but nothing works. A ridiculous flaw with seemingly no solution! Makes me think twice (or more) before buying any more Apple products in the future. My shortlist for the holiday season was an entry level MacBook Air and an IPAD, but now I'm not too sure if we have to look forward to more of this sort of thing.
    Michael Selinger - Réponse
  4. Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet: étape 4, image 1 de 1
    • Une fois la connexion réseau établie, une barre de progression apparaîtra sous le globe.
    • Cette étape est susceptible de s'arrêter au bout d'un certain temps. Si vous rencontrez une erreur, réessayez en utilisant une connexion filaire plutôt que le Wi-Fi pour vous connecter à Internet. En fonction de votre modèle, il vous faudra peut-être un adaptateur.
    Coloco la clave wi fi la reconoce pero no me carga nada, se queda conectado pero sin cargar nada
    federicorabanez - Réponse
    de que año es la maquina? Podría ser que la red no tiene conexión? Tal vez pueda probarlo con una conexión por cable.
    Taylor Dixon -
    Coloco la clave wi fi, y la reconoce pero el globo continua rotando hasta que se detiene y muestra error casi que indefinidamente. Algunas veces se congela y muestra error 2002F… no se que hacer
    Luis Hartmann - Réponse
    Hi, what if nothing happens once a connection is established? It just connects to the wifi and then goes back to previous page
    Allie Wilson - Réponse
    Hi
    I get the spinning globe and progress bar, then it goes to grey screen with apple logo and spinning loading icon then just goes to grey screen :( 2011 macbook pro.
    Plz help.
    morgan phone - Réponse
    It happened the same to me! Could you find a solution? Thanks
    Christian Cinetto -
    I have exactly the same problem on a 2011 macbook pro, nothing happens after the internet recovery loading
    furansu-182 -
    And I have the same problem on my pro 15 2011😔
    defsokal -
    I cannot type in my password, that includes numbers. If I want to type in for example number 3, instead a # appears. Is there a way to fix that problem?
    Kaweh1395 - Réponse
    The process just skips the Wi-Fi connection process. It loads the disk utility but no Wi-Fi connection. Try to load operating system it says you need Wi-Fi connection? How do I get to Wi-Fi connection process?
    jim anderson - Réponse
  5. Comment démarrer un Mac à partir de la fonctionnalité de récupération Internet: étape 5, image 1 de 1
    • Une fois la récupération Internet chargée, vous verrez s'afficher l'écran de récupération macOS.
    After I entered password and loaded up internet recovery a Question Mark appears and flashing. What do I do next?
    Dennis Fessler - Réponse
    Never mind. When I tried a second time it went to the Disk Utility. I was able to complete the process.
    Quanto tempo ci mette di solito a ricaricarsi Internet Recovery ???
    Betty Bi - Réponse
    Apple und die Time Maschine die alles kaputt macht. Statt Itunes hätten sie lieber die Time Maschine raus nehmen sollen aus Catalina Betriebssystem Apple
    Planet der Giganten - Réponse
    mi Mac lleva más de una hora y está hasta la mitad de la barra
    Matías Fonseca५ప - Réponse
    A mi me carga hasta la mitad luego se reinicia,mi máquina tiene el problema que se reinicia constantemente pero me deja acceder al modo seguro
    asesino97ful - Réponse
    Can I backup data from internet recovery to an external drive before reinstalling operating system?
    Sara - Réponse
    So, if I have a time machine backup, I chose that? I am replacing my SSD and going from the stock unit to the 1G.
    acm332 - Réponse
    Bonjour
    Merci pour votre article.
    J’ai une question à laquelle je n’ai trouvé aucune réponse. Comment désactiver la mise en veille lors d’une clean install? Je dois rester constamment rester devant l’écran pour éviter une perte de connexion et un temps d’installation plus long…
    Layanah - Réponse
    I tried. It it didn’t go beyond globe and I tried for couple of hours. Pls advise
    San D - Réponse
    Saludos. Al entrar el password pasan unos minutos y se apaga. Que puedo hacer?
    Melissa - Réponse
    it doesn’t send me to macOS but to a white screen, what do i do?
    julia - Réponse
    I have te same problem. It finishes the load screen, and then the screen turns white, the laptop starts to get hot and then turns off...
    Tobal -
    Same, white screen with little apple in middle. Did you guys figure it out?
    Jennifer Casares -
    nach dem runterladen bekomme ich eine Fehlermeldung. Habe keine Festplatte angeschlossen.
    Hab beim löschen versehentlich mcOS nicht sofort neu installiert
    Ceddi^-^ - Réponse
    After following all the steps and waiting an hour I get message
    Can’t download additional components to install Mac OS system
    Whe press OK goes back to start and again does same after an hour ?
    Ant advice ?
    Amr
    Marzouk - Réponse
    What size it takes? It writes "About 13 hours and 27 miniutes remaining.
    What is the system size??
    Plz
    Esmail Alsawraqi - Réponse
Dans les menus de récupération, vous pouvez restaurer vos données à partir d'une sauvegarde Time Machine, réinstaller macOS, obtenir de l'aide en ligne, et utiliser l'Utilitaire de disque pour formater ou diagnostiquer des problèmes avec des lecteurs de stockage connectés.
59 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Taylor Dixon
Membre depuis le 06/26/18
67 290 Réputation
94 tutoriels rédigés
40 commentaires
Apparently PowerBook G4 12” does not work for restoral based upon this exercise?
72Yonatan - Réponse
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
Taylor Dixon -
So a mid 2009 computer won’t have internet recovery mode?
Carlos Perdomo - Réponse
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
GBish - Réponse
Two main reasons:
- You aren’t pushing deep enough your new ssd drive into the slot. Please reopen your mac, unplug the battery connector and push the new ssd to a fashion position.
- Your are missing the Alt/Option key. Please make the full shorcut: Alt+Shift+R.
Orlando Gomez -
Hi there
I recently replaced the HDD in my iMac 2019, 27” Retina 5K with a OWC 1TB SSD which I formatted before installation. After installing the SSD drive my iMac won’t boot up. I’ve tried everything but to no avail. When I turn the power button on nothing happens unless I continuously hold it and then only the fan comes on. Do you have any ideas what could be the problem?
Joseph
JOSEPH BROWN - Réponse
Hey Joseph! There are a couple things that could be wrong here. I recommend you follow the steps laid out in this Answers post: iMac will not power on except fans, and when you get to the SDRAM step, instead put back the original HDD to see if that works. (Not that that’s the permanent solution—it’s just a problem solving step.) Hopefully it’s just a loose connector somewhere!
Taylor Dixon -
So I’ve followed these instructions and nothing happens. I reach the screen that shows the spinning globe but then it just stops. The Apple logo appears and sits there inactive. It never updates with the reinstall screen and there no options to update, either via the time machine back up or to reinstall the MAC OS system.
Nicholas Thomas - Réponse
Forgot to state, I have a mid 2011 27” iMac.
Hey Nicholas, since you’re on the tail end of the compatibility list you might need to force your EFI firmware update. You can find the download link here: EFI firmware update list. If you’ve already done that (or you don’t have the ability to boot back into macOS anymore), I would try again with a stable, wired internet connection.
If you can’t get internet recovery to work, you can always create a bootable macOS drive with another macOS machine and use that as a recovery drive in a pinch. Hope this helps!
Taylor Dixon -
help me please, i want to reset my MacBook pro but when i'm click command+R MacBook show like step 3, but i can't input wifi password because my keyboard can't working but the capslock button is working. so what can i do?
pika - Réponse
pika, try plugging in an external keyboard to input the WiFi password!
Taylor Dixon -
I need help please!! I’ve chosen the wifi for the laptop to connect to but it’s just takes me back to the spinning globe and the wifi options. It doesn’t show that it is loading. How do I fix this so I can move forward to the next step?
Gigi - Réponse
Hey Gigi! It sounds like either your WiFi password isn’t correct, or the computer can’t connect to the internet with that network for some other reason. I would try your password again, and if that doesn’t work you can try to connect using an ethernet cable—or just take it to a friend’s house and try their WiFi!
Taylor Dixon -
Hi! I have followed these steps, the world is spinning and there is a time bar and under the bar is 24:00 and it has been stuck on there for over an hour, it never popped up and asked me to input my wifi information either? Help!!
Danielle Starr - Réponse
Danielle, that’s a weird one! Normally the time bar only shows up if you have slow internet, but if it didn’t ask for your wifi information then that’s definitely unexpected behavior. Can you try using an ethernet cable to hardwire internet to the computer? That way you won’t need to use wifi anyway, and hopefully it will be able to boot to internet recovery. Hopefully that workaround will get the job done, keep us posted!
Taylor Dixon -
Time Machine doesn’t work, reinstalling the OS X doesn’t work, and system utility doesn’t show my hd . What do I do?
johnthompson111 - Réponse
J’arrive à l’avant dernière étape et après celle là la cinquième étape ne s’affiche pas et m’en remet sur «  saisissez le code pin de verouillage de votre système pour déverrouiller ce Mac «  je n’arrive pas à aller à labo dernière etape
Lou - Réponse
J’arrive jusqu’à la quatrième étape mais après sa me met saisissez le code pin de verouillage de votre système pour déverrouillé ce Mac je ne comprend pas
Lou - Réponse
Hi I have done all of the above steps and the globe remain spining but instead of the progress bar it simply has the new of the WiFi connection under it? Any help? Kinda panicking a little here
Pj Reilly - Réponse
What if it says to select the disk where to install macOS Big Sur, but no disk is showing, it just lets me click back
David Hall - Réponse
Hello, I have tried the above steps but everything stopped after the bar is fully loaded and shows a “Warning Sign” in the world icon with “apple.com/support", underneath it is -2100F.
Please what can I do next?
David Ebong - Réponse
Hello,
can you help me please ?
how can I leave this mode?
The combination keys I mean
Regards
MacBook Pro 2018
Abdoulaye Cissé - Réponse
Utilities does not come up for me only after the spinning globe a page to choose language pops up and then the options to shut down or restart are prompted
moh Visions - Réponse
I’ve been trying to get back to the Home Screen but it won’t let me
Sue Burgess - Réponse
recovery stop with error 1008F
H K - Réponse
Spinning globe and internet connection but no progress bar. What can I do?
bigolddogman - Réponse
Hi! What’s does that mean:
Earth with triangle with “!” plus that text
apple.com/support
-3403F
Thanks
christian
Christian Spindler - Réponse
PS: tried it several times and checkt netzwork cable/internet connection - was O.K. but Then it was successful. Happy whis understands that…
&&^& u apple headed bitxhs
showtyme2828 - Réponse
I am ok up to step 4 but unfortunately the Mac OS utilities screen doesn’t appear. Only le apple logo
Mps - Réponse
I hade this error when going to recover mode -2002f
Prakash Chavan - Réponse
Bei meinem 27", Ende 2011, lässt sich die Prozedur auslösen und der Ladebalken unter der Weltkugel öffnet sich, doch nach 30sek. stoppt der Ladevorgang und ein Uhrsymbol zeigt 24:00. Was bedeutet das?
Wig Hensi - Réponse
At the bottom of the screen that says activate Mac it says select wi-fi network and in the upper right hand corner it has the apple logo and recovery assistant. How do I get my MacBook pro to restart
Taris Brown - Réponse
After connecting to the internet my Mac keep showing the globe and the option to chose a network. Do you know how to fix it ? Cheers
Abner lucas nogueira - Réponse
Ant advice ?
Amr
Marzouk - Réponse
It get to a screen that looks like a phone or something with a swipe button, then something that looks kind of like a tablet screen and it’s showing a power button on the side.
Gordon Browne - Réponse
Hi my mac crashed and now i am not able to boot via usb nor the internet. After restarting and pressing the command option r my mac comes up with a lock logo which asks for a password which i donot remember. I have put in all possible passwords but cannot go past it. Kindly help!
Yogesh Chand Thakur - Réponse
Very helpful and I was able to be successful at restoring my system. Thank you. Now for the next task and accomplishment to achieve.
Indigenous Willd Flowers - Réponse
Super useful, worked for me!
Fernande Tester - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 175
7 derniers jours : 1,379
30 derniers jours : 6,245
Total : 469,511
