Introduction
Use this guide to replace a worn-out or dead battery in your Huawei Mate 20.
Opening the Huawei Mate 20 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Although it is possible to remove the battery without removing the main flex cable, we recommend to do so to avoid damage to surrounding components.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ce dont vous avez besoin
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Remove the four Phillips #00 screws (3.3 mm length).
Remove the two Phillips #00 screws (3.9 mm length).
Use a spudger to pry up and disconnect the connector on the bottom end of the main flex cable.
Apply adhesive remover or high isopropyl alcohol (>90%) in every corner of the battery and let it penetrate the adhesive beneath the battery for several minutes.
At this point you can attempt to continue with the following steps. If you aren't able to pry up the battery apply a heated iOpener to the screen to loosen the adhesive beneath. Apply the iOpener for at least two minutes. You may need to repeat the adhesive remover and heat procedure several times during the removal procedure.
Insert a spudger into the gap between the midframe and the battery at the bottom left corner of the battery.
Use the spudger to pry up the battery until you created a small gap underneath. Try your best not to deform the battery during this procedure.
Apply some more adhesive remover into the created gap and let it penetrate the adhesive for several minutes.
Outil utilisé dans cette étape :Plastic Cards$2.99
Slide a plastic card into the gap you created with the spudger.
If you cannot manage to slide the plastic card along the left side of the battery leave it in its place and apply more adhesive remover or heat to loosen the adhesive furthermore.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 autres ont terminé cette réparation.
