Aller au contenu principal
Pour réparer ensemble - Je crée un compte
IdeaPad L340-15API Battery Replacement
Ce dont vous avez besoin
  1. IdeaPad L340-15API Battery Replacement, Optical Drive: étape 1, image 1 de 2 IdeaPad L340-15API Battery Replacement, Optical Drive: étape 1, image 2 de 2
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    Demander à FixBot
    Ajouter un commentaire
  2. IdeaPad L340-15API Battery Replacement: étape 2, image 1 de 2 IdeaPad L340-15API Battery Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    Demander à FixBot
  3. IdeaPad L340-15API Battery Replacement: étape 3, image 1 de 2 IdeaPad L340-15API Battery Replacement: étape 3, image 2 de 2
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    Demander à FixBot
  4. IdeaPad L340-15API Battery Replacement, Battery: étape 4, image 1 de 2 IdeaPad L340-15API Battery Replacement, Battery: étape 4, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    Demander à FixBot
  5. IdeaPad L340-15API Battery Replacement: étape 5, image 1 de 3 IdeaPad L340-15API Battery Replacement: étape 5, image 2 de 3 IdeaPad L340-15API Battery Replacement: étape 5, image 3 de 3
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    Demander à FixBot
  6. IdeaPad L340-15API Battery Replacement: étape 6, image 1 de 2 IdeaPad L340-15API Battery Replacement: étape 6, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    Demander à FixBot
  7. IdeaPad L340-15API Battery Replacement: étape 7, image 1 de 3 IdeaPad L340-15API Battery Replacement: étape 7, image 2 de 3 IdeaPad L340-15API Battery Replacement: étape 7, image 3 de 3
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    Demander à FixBot
  8. IdeaPad L340-15API Battery Replacement: étape 8, image 1 de 1
    • Remove the battery from the laptop.
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Ian
Membre depuis le 10/15/25
347 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Membre de l'équipe UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 57
Total : 373
