Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG Front Load Washing Machine Rotor Replacement
Ce dont vous avez besoin
  1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: étape 1, image 1 de 2 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Demander à FixBot
    Ajouter un commentaire
  2. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: étape 2, image 1 de 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: étape 2, image 2 de 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: étape 2, image 3 de 3
    • Remove the screw(s) securing the rear panel.
    Demander à FixBot
  3. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: étape 3, image 1 de 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: étape 3, image 2 de 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: étape 3, image 3 de 3
    • Unclip the rear panel from the chassis.
    Demander à FixBot
  4. LG Front Load Washing Machine Rotor Replacement: étape 4, image 1 de 1
    • Remove the rear panel.
    Demander à FixBot
  5. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: étape 5, image 1 de 2 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: étape 5, image 2 de 2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
    Demander à FixBot
  6. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: étape 6, image 1 de 2 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: étape 6, image 2 de 2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
    Demander à FixBot
Repair didn’t go as planned? Ask our Answers community for help.
2 autres ont terminé cette réparation.
Bill Gilbert
Membre depuis le 06/30/22
40 146 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
32 274 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 27
30 derniers jours : 86
Total : 2,317
