Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG Refrigerator Control Board Replacement
Ce dont vous avez besoin
    1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: étape 1, image 1 de 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Demander à FixBot
      Ajouter un commentaire
    1. LG Refrigerator Control Board Replacement, Unfasten the control board cover: étape 2, image 1 de 1
      • Use a Phillips screwdriver to remove the screws securing the control board cover.
      Demander à FixBot
    2. LG Refrigerator Control Board Replacement, Remove the control board cover: étape 3, image 1 de 3 LG Refrigerator Control Board Replacement, Remove the control board cover: étape 3, image 2 de 3 LG Refrigerator Control Board Replacement, Remove the control board cover: étape 3, image 3 de 3
      • Tilt the top edge of the cover toward you and lift it off.
      Demander à FixBot
    1. LG Refrigerator Control Board Replacement, Disconnect the control board: étape 4, image 1 de 3 LG Refrigerator Control Board Replacement, Disconnect the control board: étape 4, image 2 de 3 LG Refrigerator Control Board Replacement, Disconnect the control board: étape 4, image 3 de 3
      • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
      • Squeeze and pull the connectors to disconnect them from the control board.
      • Make sure to fully reconnect each connector when reassembling.
      Demander à FixBot
    2. LG Refrigerator Control Board Replacement, Release the control board: étape 5, image 1 de 3 LG Refrigerator Control Board Replacement, Release the control board: étape 5, image 2 de 3 LG Refrigerator Control Board Replacement, Release the control board: étape 5, image 3 de 3
      • Use your thumb to pry up and release the top left retaining clip securing the control board.
      • With your other hand, pull the top left corner of the control board out to loosen it.
      Demander à FixBot
    3. LG Refrigerator Control Board Replacement: étape 6, image 1 de 3 LG Refrigerator Control Board Replacement: étape 6, image 2 de 3 LG Refrigerator Control Board Replacement: étape 6, image 3 de 3
      • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
      Demander à FixBot
    4. LG Refrigerator Control Board Replacement, Remove the control board: étape 7, image 1 de 1
      • Lift the control board out by its edges and remove it.
      Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
4 autres ont terminé cette réparation.
Bill Gilbert
Membre depuis le 06/30/22
40 159 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
38 648 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 67
30 derniers jours : 247
Total : 4,941
