Aller au contenu principal
Lenovo ThinkPad T480s Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 2 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 3 de 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 6, image 3 de 3
    • Slide the Wi-Fi card out from the slot.
Sarah Westberg
Membre depuis le 03/11/19
29 665 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 583 tutoriels rédigés
Un commentaire
Hi, thanks a lot the helpful guide. I have just replaced the WiFi card in my Lenovo T480s with a Intel AX210NGW. My laptop won't boot up. Even when I plug the power adapter into the laptop, the status indicator does not light up. I have removed the WiFi card and tried to power it on without it but no luck. I put back the one that was in before still no luck. I'm stuck, what can I do? Did some power component get disturbed or something? I'd appreciate any help. Thank you.
Michael Kasede - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 39
30 derniers jours : 143
Total : 3,367
