Aller au contenu principal
Lenovo ThinkPad T480s Wi-Fi Card Replacement
Sarah Westberg
Sarah Westberg et un autre contributeur
Dernière mise à jour le March 20, 2024
10 - 15 minutes
Modérée
This guide will show you how to replace the Wi-Fi card in a Lenovo ThinkPad T480s laptop.
A Wi-Fi card, also known as a WLAN card, enables the laptop to connect to a wireless network. If you cannot connect your laptop to Wi-Fi, or if you are experiencing intermittent connectivity, you may have a faulty Wi-Fi card. Be sure to rule out other connectivity issues listed here before replacing your Wi-Fi card.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Ce dont vous avez besoin
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: étape 1, image 2 de 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
    Somehow I find the screws for the T480s bottom cover to be slightly more prone to stripping, compared to the ThinkPad T480 and X1 Carbon Gen 6. However, the #1 Phillips screws on the T480s have drives that are cut in a way that also let you use a #3 flathead.
    Tai Lam - Réponse
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 2 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: étape 4, image 3 de 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: étape 6, image 3 de 3
    • Slide the Wi-Fi card out from the slot.
Sarah Westberg
Membre depuis le 03/11/19
30 283 Réputation
71 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
20 074 tutoriels rédigés
1 commentaire de tutoriel
Hi, thanks a lot the helpful guide. I have just replaced the WiFi card in my Lenovo T480s with a Intel AX210NGW. My laptop won't boot up. Even when I plug the power adapter into the laptop, the status indicator does not light up. I have removed the WiFi card and tried to power it on without it but no luck. I put back the one that was in before still no luck. I'm stuck, what can I do? Did some power component get disturbed or something? I'd appreciate any help. Thank you.
Michael Kasede - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 37
30 derniers jours : 138
Total : 3,532
