Aller au contenu principal
Lenovo Thinkpad T450 Internal Battery Replacement
Ce dont vous avez besoin
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: étape 1, image 1 de 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: étape 1, image 2 de 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: étape 1, image 3 de 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: étape 2, image 1 de 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: étape 3, image 1 de 3 Lenovo Thinkpad T450 Internal Battery Replacement: étape 3, image 2 de 3 Lenovo Thinkpad T450 Internal Battery Replacement: étape 3, image 3 de 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: étape 4, image 1 de 2 Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: étape 4, image 2 de 2
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: étape 5, image 1 de 2 Lenovo Thinkpad T450 Internal Battery Replacement: étape 5, image 2 de 2
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: étape 6, image 1 de 1
    • Lift up and remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 autres ont terminé cette réparation.
Justin Ogihara
Membre depuis le 09/18/17
27 230 Réputation
52 tutoriels rédigés
Équipe
EDU Team Membre de l'équipe EDU Team
Staff
7 membres
637 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 31
30 derniers jours : 161
Total : 4,383
