Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Levoit Core 300-RAC Control Board Replacement
Ce dont vous avez besoin
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: étape 1, image 1 de 3 Levoit Core 300-RAC Control Board Replacement, Control Board: étape 1, image 2 de 3 Levoit Core 300-RAC Control Board Replacement, Control Board: étape 1, image 3 de 3
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      Demander à FixBot
      Ajouter un commentaire
    2. Levoit Core 300-RAC Control Board Replacement: étape 2, image 1 de 3 Levoit Core 300-RAC Control Board Replacement: étape 2, image 2 de 3 Levoit Core 300-RAC Control Board Replacement: étape 2, image 3 de 3
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      Demander à FixBot
    3. Levoit Core 300-RAC Control Board Replacement: étape 3, image 1 de 2 Levoit Core 300-RAC Control Board Replacement: étape 3, image 2 de 2
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      Demander à FixBot
    4. Levoit Core 300-RAC Control Board Replacement: étape 4, image 1 de 3 Levoit Core 300-RAC Control Board Replacement: étape 4, image 2 de 3 Levoit Core 300-RAC Control Board Replacement: étape 4, image 3 de 3
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      Demander à FixBot
Mustafa
Membre depuis le 11/03/23
259 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 92
Total : 1,906
