Aller au contenu principal
Pour réparer ensemble - Je crée un compte
MSI MS-1782 GPU Replacement
Ce dont vous avez besoin
  1. MSI MS-1782 GPU Replacement, Back Cover: étape 1, image 1 de 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. MSI MS-1782 GPU Replacement: étape 2, image 1 de 3 MSI MS-1782 GPU Replacement: étape 2, image 2 de 3 MSI MS-1782 GPU Replacement: étape 2, image 3 de 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
    Demander à FixBot
  3. MSI MS-1782 GPU Replacement, Cooling Assembly: étape 3, image 1 de 3 MSI MS-1782 GPU Replacement, Cooling Assembly: étape 3, image 2 de 3 MSI MS-1782 GPU Replacement, Cooling Assembly: étape 3, image 3 de 3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
    Demander à FixBot
  4. MSI MS-1782 GPU Replacement: étape 4, image 1 de 3 MSI MS-1782 GPU Replacement: étape 4, image 2 de 3 MSI MS-1782 GPU Replacement: étape 4, image 3 de 3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
    Demander à FixBot
  5. MSI MS-1782 GPU Replacement: étape 5, image 1 de 3 MSI MS-1782 GPU Replacement: étape 5, image 2 de 3 MSI MS-1782 GPU Replacement: étape 5, image 3 de 3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
    Demander à FixBot
  6. MSI MS-1782 GPU Replacement: étape 6, image 1 de 3 MSI MS-1782 GPU Replacement: étape 6, image 2 de 3 MSI MS-1782 GPU Replacement: étape 6, image 3 de 3
    Demander à FixBot
  7. MSI MS-1782 GPU Replacement: étape 7, image 1 de 3 MSI MS-1782 GPU Replacement: étape 7, image 2 de 3 MSI MS-1782 GPU Replacement: étape 7, image 3 de 3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
    Demander à FixBot
  8. MSI MS-1782 GPU Replacement: étape 8, image 1 de 3 MSI MS-1782 GPU Replacement: étape 8, image 2 de 3 MSI MS-1782 GPU Replacement: étape 8, image 3 de 3
    • Gently lift the heat sink and then pull forwards towards you.
    Demander à FixBot
  9. MSI MS-1782 GPU Replacement, GPU: étape 9, image 1 de 3 MSI MS-1782 GPU Replacement, GPU: étape 9, image 2 de 3 MSI MS-1782 GPU Replacement, GPU: étape 9, image 3 de 3
    • Remove the two 5.0 mm screws holding the GPU by using a JIS #1 screwdriver.
    Demander à FixBot
  10. MSI MS-1782 GPU Replacement: étape 10, image 1 de 3 MSI MS-1782 GPU Replacement: étape 10, image 2 de 3 MSI MS-1782 GPU Replacement: étape 10, image 3 de 3
    • Gently lift the GPU and pull to remove it from the laptop.
    Demander à FixBot
Enmanuel Mota
Membre depuis le 03/08/23
229 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 28
Total : 847
