Aller au contenu principal
MacBook Air 13" Early 2020 Microphone Array Replacement
Ce dont vous avez besoin
  1. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the screws securing the lower case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $16.96
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the lower case: étape 2, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the lower case: étape 2, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the lower case: étape 2, image 3 de 3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the battery: étape 3, image 1 de 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 4, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 4, image 2 de 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the left speaker connector: étape 5, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the left speaker connector: étape 5, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the left speaker connector: étape 5, image 3 de 3
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  6. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the left speaker screw: étape 6, image 1 de 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
  7. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: étape 7, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: étape 7, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the speaker's stretch-release adhesive: étape 7, image 3 de 3
    • Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
    • Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Pull the adhesive strip until it's freed from under the speaker.
    • If the adhesive strip breaks, use a heated iOpener, a heat gun, or a hair dryer to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the left speaker: étape 8, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the left speaker: étape 8, image 2 de 2
    Tesa 61395 Tape
    $5.99
    • Remove the left speaker.
    • During reassembly, to ensure the speaker performs as expected, install a strip of replacement adhesive on its underside before placing it back into the case.
  9. MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the right speaker connector: étape 9, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the right speaker connector: étape 9, image 2 de 2
    • The right speaker will be on your lefthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
  10. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the right speaker screw: étape 10, image 1 de 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
  11. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the right speaker adhesive: étape 11, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the right speaker adhesive: étape 11, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the right speaker adhesive: étape 11, image 3 de 3
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
  12. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the right speaker: étape 12, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the right speaker: étape 12, image 2 de 2
    Tesa 61395 Tape
    $5.99
    • Remove the right speaker.
  13. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the trackpad cable cover: étape 13, image 1 de 1
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
  14. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 14, image 1 de 1
    • Remove the trackpad cable cover.
  15. MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the trackpad cable: étape 15, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the trackpad cable: étape 15, image 2 de 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  16. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 16, image 1 de 1
    • Carefully peel the trackpad cable off of the battery.
    • The trackpad cable is secured to the battery with some light adhesive.
  17. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the battery tray screws: étape 17, image 1 de 1
    • Use a T3 Torx driver to remove two 2.5 mm screws securing the battery tray to the case.
  18. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the battery tray adhesive strips: étape 18, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the battery tray adhesive strips: étape 18, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the battery tray adhesive strips: étape 18, image 3 de 3
    • The MacBook's battery cells are attached to a metal tray as a complete assembly, which is adhered to the case with a total of six stretch-release adhesive strips.
    • Do not attempt to remove the battery cells from their metal backing tray.
    • On the left side of the MacBook, use a pair of tweezers to peel back the three black pull tabs on the battery's stretch-release adhesive strips until you can grip them with your fingers.
  19. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 19, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 19, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 19, image 3 de 3
    • Grab an adhesive strip's pull tab and slowly pull it out from underneath the battery.
    • Pull the adhesive strip until it's freed from under the battery.
    • Repeat for the two remaining adhesive strips on the battery's left side.
  20. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 20, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 20, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 20, image 3 de 3
    Plastic Cards
    $2.99
    • Repeat and remove the three adhesive strips from the right side of the battery.
    • If any of the six adhesive strips broke during removal, you can use a plastic card to finish separating the battery tray from the case.
  21. MacBook Air 13" Early 2020 Microphone Array Replacement, Remove the battery: étape 21, image 1 de 1
    Tesa 61395 Tape
    $5.99
    • Remove the battery assembly.
    • During reassembly, secure the battery tray with strips of Tesa tape if your replacement battery doesn't come with pre-applied adhesive.
    • If you're installing a new battery, follow the calibration procedure:
    • Charge it to 100%, and keep charging it for at least 2 more hours.
    • Unplug and use it normally to drain the battery.
    • When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery.
    • Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  22. MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the microphone cable: étape 22, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement, Disconnect the microphone cable: étape 22, image 2 de 2
    • Use a pair of tweezers to peel back the tape covering the microphone cable connector.
  23. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 23, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 23, image 2 de 2
    • Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
  24. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 24, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 24, image 2 de 2
    • Slide the microphone cable out of its connector.
    • If possible, grip the cable by the tape, not by the cable itself.
  25. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 25, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 25, image 2 de 2
    • Slide an opening pick underneath the microphone cable to separate it from the upper case.
    • The cable is secured with some light adhesive.
    • If the adhesive is stubborn, do not force the pick. Lightly heat the microphone assembly using an iOpener or a hair dryer to soften the adhesive.
  26. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 26, image 1 de 2 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 26, image 2 de 2
    • Slide an opening pick underneath the microphone closest to the center of the MacBook to slice through the adhesive securing it to the upper case.
    • Lift up to pry the microphone out of its recess in the case.
  27. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 27, image 1 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 27, image 2 de 3 MacBook Air 13" Early 2020 Microphone Array Replacement: étape 27, image 3 de 3
    • Use the pointed end of a spudger to carefully pry one of the remaining microphones out of its recess in the upper case.
    • If the adhesive is stubborn, apply heat to the microphone to soften the adhesive.
    • Don't force the spudger under the microphone or you risk ripping the cable.
    • Remove the third and final microphone from the case.
  28. MacBook Air 13" Early 2020 Microphone Array Replacement: étape 28, image 1 de 1
    • Remove the microphone array.
Carsten Frauenheim
Membre depuis le 03/10/20
155 244 Réputation
439 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 608 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 48
Total : 1,845
