Aller au contenu principal
Meta Quest 2 Eyepiece Trim Replacement
Ce dont vous avez besoin
  1. Meta Quest 2 Eyepiece Trim Replacement, Power off your Meta Quest 2: étape 1, image 1 de 1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Eyepiece Trim Replacement, Remove the facial interface: étape 2, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the facial interface: étape 2, image 2 de 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Eyepiece Trim Replacement: étape 3, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement: étape 3, image 2 de 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Eyepiece Trim Replacement: étape 4, image 1 de 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: étape 5, image 1 de 3 Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: étape 5, image 2 de 3 Meta Quest 2 Eyepiece Trim Replacement, Unclip the side straps: étape 5, image 3 de 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Eyepiece Trim Replacement: étape 6, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement: étape 6, image 2 de 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Eyepiece Trim Replacement, Remove the top strap: étape 7, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the top strap: étape 7, image 2 de 2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Eyepiece Trim Replacement, Remove the head strap: étape 8, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the head strap: étape 8, image 2 de 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim screws: étape 9, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim screws: étape 9, image 2 de 2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Eyepiece Trim Replacement, Release the eyepiece trim clips: étape 10, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement, Release the eyepiece trim clips: étape 10, image 2 de 2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Eyepiece Trim Replacement: étape 11, image 1 de 3 Meta Quest 2 Eyepiece Trim Replacement: étape 11, image 2 de 3 Meta Quest 2 Eyepiece Trim Replacement: étape 11, image 3 de 3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Eyepiece Trim Replacement: étape 12, image 1 de 3 Meta Quest 2 Eyepiece Trim Replacement: étape 12, image 2 de 3 Meta Quest 2 Eyepiece Trim Replacement: étape 12, image 3 de 3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: étape 13, image 1 de 3 Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: étape 13, image 2 de 3 Meta Quest 2 Eyepiece Trim Replacement, Reposition the eyepiece trim: étape 13, image 3 de 3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: étape 14, image 1 de 3 Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: étape 14, image 2 de 3 Meta Quest 2 Eyepiece Trim Replacement, Disconnect the face sensor: étape 14, image 3 de 3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Eyepiece Trim Replacement: étape 15, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement: étape 15, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Eyepiece Trim Replacement, Remove the eyepiece trim: étape 16, image 1 de 1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: étape 17, image 1 de 2 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: étape 17, image 2 de 2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: étape 18, image 1 de 3 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: étape 18, image 2 de 3 Meta Quest 2 Eyepiece Trim Replacement, Reassembly note: étape 18, image 3 de 3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
Arthur Shi
Membre depuis le 01/03/18
281 659 Réputation
584 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 410 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 13
30 derniers jours : 60
Total : 1,053
