Introduction
This guide will walk you through the process of opening and replacing the camera
Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
Slide the ribbon out of the ZIF connector.
Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing.
Underneath the rubber is a silver sticky
Using the PH00 screw driver, remove the screws.
The camera should be loose, just lift carefully.
the cable that is attached to it, should be easy to remove from the bottom half of the DS.
Un commentaire
This doesn't actually show how to get the new camera in, I managed to pull the cable of the old one out but I have no idea how to get the new one through the hinge cover wrapping surround the wires
