Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokia 3100b Microphone Replacement
Ce dont vous avez besoin
  1. Nokia 3100b Microphone Replacement, Battery: étape 1, image 1 de 1
    • Make sure your phone is turned off.
    Demander à FixBot
    Ajouter un commentaire
  2. Nokia 3100b Microphone Replacement: étape 2, image 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Demander à FixBot
  3. Nokia 3100b Microphone Replacement, SIM Card: étape 3, image 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Demander à FixBot
  4. Nokia 3100b Microphone Replacement: étape 4, image 1 de 1
    • Retrieve your SIM card.
    Demander à FixBot
  5. Nokia 3100b Microphone Replacement, Microphone: étape 5, image 1 de 1
    • Press the black tabs to release the front cover from the phone.
    Demander à FixBot
  6. Nokia 3100b Microphone Replacement: étape 6, image 1 de 1
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
    Demander à FixBot
  7. Nokia 3100b Microphone Replacement: étape 7, image 1 de 2 Nokia 3100b Microphone Replacement: étape 7, image 2 de 2
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
    Demander à FixBot
  8. Nokia 3100b Microphone Replacement: étape 8, image 1 de 3 Nokia 3100b Microphone Replacement: étape 8, image 2 de 3 Nokia 3100b Microphone Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
    Demander à FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sterling Fuentes
Membre depuis le 04/09/10
139 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 29-64, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 36
Total : 2,463
