Aller au contenu principal
OnePlus 6T Motherboard Replacement
Ce dont vous avez besoin
  1. OnePlus 6T Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Motherboard Replacement: étape 2, image 1 de 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Motherboard Replacement: étape 3, image 1 de 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Motherboard Replacement: étape 4, image 1 de 3 OnePlus 6T Motherboard Replacement: étape 4, image 2 de 3 OnePlus 6T Motherboard Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Motherboard Replacement, Front Camera: étape 5, image 1 de 2 OnePlus 6T Motherboard Replacement, Front Camera: étape 5, image 2 de 2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Motherboard Replacement: étape 6, image 1 de 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Motherboard Replacement: étape 7, image 1 de 1
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Motherboard Replacement: étape 8, image 1 de 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
  9. OnePlus 6T Motherboard Replacement, Motherboard: étape 9, image 1 de 2 OnePlus 6T Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
  10. OnePlus 6T Motherboard Replacement: étape 10, image 1 de 1
    • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
  11. OnePlus 6T Motherboard Replacement: étape 11, image 1 de 1
    • Use a spudger to disconnect the signal cables on the right side of the motherboard.
  12. OnePlus 6T Motherboard Replacement: étape 12, image 1 de 2 OnePlus 6T Motherboard Replacement: étape 12, image 2 de 2
    • Disconnect the slider from the top of the phone with a spudger.
    • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
    • Gently pull the motherboard from the left side and remove it from the phone.
3 autres ont terminé cette réparation.
Kristen Gismondi
Membre depuis le 11/12/14
81 969 Réputation
200 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 198 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 49
Total : 3,964
