Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 8 Rear Glass Replacement
Vues: 4,4 k
Afficher les statistiques :
Dernières 24 heures :
3
Sept derniers jours :
35
Trente derniers jours :
123
Total :
4 387
Commentaires: 1
1 commentaire de tutoriel.
Aller aux commentaires de tutoriel
Terminé: 1
1 personne a marqué ce tutoriel comme « terminé ». Serez-vous la prochaine ?
Favoris: 1
1 personne a mis ce tutoriel en favori (et s'y est abonnée). Serez-vous la prochaine ?
Temps nécessaire: 20 - 40 minutes
Difficulté: Modérée
Use this guide to replace a broken rear glass panel on your OnePlus 8.
You'll need replacement adhesive in order to complete this repair.
Note: Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating. However, only the T-Mobile (IN2017) and Verizon (IN2019) models offer IP ratings.
Ce dont vous avez besoin
Pièces
Outils
    1. OnePlus 8 Rear Glass Replacement, Heat the rear glass: étape 1, image 1 de 1
      • Power off your phone and unplug any cables.
      • Heat an iOpener and apply it to the rear glass for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
      Demander à FixBot
      Ajouter un commentaire
    2. OnePlus 8 Rear Glass Replacement, Insert an opening pick: étape 2, image 1 de 3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: étape 2, image 2 de 3 OnePlus 8 Rear Glass Replacement, Insert an opening pick: étape 2, image 3 de 3
      • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
      • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
      • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
      • Insert an opening pick into the gap.
      Demander à FixBot
    3. OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: étape 3, image 1 de 3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: étape 3, image 2 de 3 OnePlus 8 Rear Glass Replacement, Slice the bottom edge adhesive: étape 3, image 3 de 3
      • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
      Demander à FixBot
    4. OnePlus 8 Rear Glass Replacement: étape 4, image 1 de 3 OnePlus 8 Rear Glass Replacement: étape 4, image 2 de 3 OnePlus 8 Rear Glass Replacement: étape 4, image 3 de 3
      • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Demander à FixBot
    5. OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: étape 5, image 1 de 3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: étape 5, image 2 de 3 OnePlus 8 Rear Glass Replacement, Slice the left edge adhesive: étape 5, image 3 de 3
      • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
      • Insert a third opening pick under the bottom left corner of the rear glass.
      • Slide the opening pick up the left edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Demander à FixBot
    6. OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: étape 6, image 1 de 3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: étape 6, image 2 de 3 OnePlus 8 Rear Glass Replacement, Slice the top edge adhesive: étape 6, image 3 de 3
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Demander à FixBot
    7. OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: étape 7, image 1 de 3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: étape 7, image 2 de 3 OnePlus 8 Rear Glass Replacement, Slice the right edge adhesive: étape 7, image 3 de 3
      • Insert a fifth opening pick under the top right corner of the rear glass.
      • Slide the opening pick down the right edge to slice the remaining adhesive.
      Demander à FixBot
    8. OnePlus 8 Rear Glass Replacement, Remove the rear glass: étape 8, image 1 de 3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: étape 8, image 2 de 3 OnePlus 8 Rear Glass Replacement, Remove the rear glass: étape 8, image 3 de 3
      • Remove the rear glass.
      • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
      • During reassembly:
      • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
      • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
      Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Auteur
avec
Manuel Haeussermann
Membre depuis le 07/13/22
27 462 Réputation
72 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
119 membres
72 955 tutoriels rédigés
hi, vielen Dank für die detaillierte Anleitung! Das hilft mega! Habt ihr evtl. noch eine Quelle, wo man das Backglass beziehen kann?
Thilo Cestonaro - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 35
30 derniers jours : 123
Total : 4,387
