Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Panasonic SA-HT810V VHS Drive Replacement
Ce dont vous avez besoin
    1. Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: étape 1, image 1 de 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: étape 1, image 2 de 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: étape 1, image 3 de 3
      • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
      • Now rotate the device 180 degrees and remove the second screw.
      • Remove the screw that is on the right side of the panel facing you.
      • All screws will need to be removed with a phillips head screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Panasonic SA-HT810V VHS Drive Replacement: étape 2, image 1 de 2 Panasonic SA-HT810V VHS Drive Replacement: étape 2, image 2 de 2
      • Rotate the device so that the back faces you.
      • With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
      Demander à FixBot
    3. Panasonic SA-HT810V VHS Drive Replacement: étape 3, image 1 de 1
      • Before removing cover make sure that the back of the device is facing you.
      • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
      Demander à FixBot
    4. Panasonic SA-HT810V VHS Drive Replacement: étape 4, image 1 de 3 Panasonic SA-HT810V VHS Drive Replacement: étape 4, image 2 de 3 Panasonic SA-HT810V VHS Drive Replacement: étape 4, image 3 de 3
      • Pull up the two tabs on top
      • Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
      • Depress the four tabs on the bottom of the device.
      Demander à FixBot
    5. Panasonic SA-HT810V VHS Drive Replacement: étape 5, image 1 de 1
      • Carefully pull off the front panel of the device.
      • The front is attached to the device with cables so be careful when removing.
      Demander à FixBot
    6. Panasonic SA-HT810V VHS Drive Replacement: étape 6, image 1 de 2 Panasonic SA-HT810V VHS Drive Replacement: étape 6, image 2 de 2
      • With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
      Demander à FixBot
    7. Panasonic SA-HT810V VHS Drive Replacement: étape 7, image 1 de 1
      • Remove the three cables attaching the VHS to the Mother Board.
      • Carefully pull the VHS drive out of the device and follow the steps in reverse to place the new one in.
      • Make sure the cables connecting the VHS Drive are fully inserted before powering the machine on to prevent damage to the internal components.
      Demander à FixBot
Nathan Cheadle
Membre depuis le 04/15/10
161 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 16-5, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 membres
32 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 44
Total : 1,524
