Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Parrot Skycontroller 2 USB Port Replacement
Ce dont vous avez besoin
  1. Parrot Skycontroller 2 USB Port Replacement, Battery: étape 1, image 1 de 3 Parrot Skycontroller 2 USB Port Replacement, Battery: étape 1, image 2 de 3 Parrot Skycontroller 2 USB Port Replacement, Battery: étape 1, image 3 de 3
    • Flip your controller face down.
    Demander à FixBot
    Ajouter un commentaire
  2. Parrot Skycontroller 2 USB Port Replacement: étape 2, image 1 de 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
    Demander à FixBot
  3. Parrot Skycontroller 2 USB Port Replacement: étape 3, image 1 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 3, image 2 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 3, image 3 de 3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    Demander à FixBot
  4. Parrot Skycontroller 2 USB Port Replacement: étape 4, image 1 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 4, image 2 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 4, image 3 de 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    Demander à FixBot
  5. Parrot Skycontroller 2 USB Port Replacement: étape 5, image 1 de 2 Parrot Skycontroller 2 USB Port Replacement: étape 5, image 2 de 2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    Demander à FixBot
  6. Parrot Skycontroller 2 USB Port Replacement, USB Port: étape 6, image 1 de 1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • Pull back the sticker with your finger nail and remove one 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    Demander à FixBot
  7. Parrot Skycontroller 2 USB Port Replacement: étape 7, image 1 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 7, image 2 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 7, image 3 de 3
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
    Demander à FixBot
  8. Parrot Skycontroller 2 USB Port Replacement: étape 8, image 1 de 1
    • Remove the battery compartment plate by pulling up and out.
    Demander à FixBot
  9. Parrot Skycontroller 2 USB Port Replacement: étape 9, image 1 de 2 Parrot Skycontroller 2 USB Port Replacement: étape 9, image 2 de 2
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
    Demander à FixBot
  10. Parrot Skycontroller 2 USB Port Replacement: étape 10, image 1 de 2 Parrot Skycontroller 2 USB Port Replacement: étape 10, image 2 de 2
    • Remove the face plate by pulling up and out.
    Demander à FixBot
  11. Parrot Skycontroller 2 USB Port Replacement: étape 11, image 1 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 11, image 2 de 3 Parrot Skycontroller 2 USB Port Replacement: étape 11, image 3 de 3
    • Position the device so that the top panel is flat down on the table. You should have access to the USB Port.
    • Desolder the two connection points in the back of the USB port.
    • Desolder the four wires in the back of the USB port.
    • Remove the the component from the board.
    • Excessive heat can damage the port, so do not apply the soldering iron to the component for too long.
    Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 28
Total : 1,173
