Introduction
If the microphone of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with an LED that turns different colors that relay what state the Petcube is in. These can include when the LED turning green when setting up, turning blue when it is streaming, and error-related colors like orange when there is no access point. A defective LED will not turn on.
Before using this guide, ensure that there are no other issues with the LED. The Troubleshooting Page covers issues that could be preventing the LED from turning on and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process. This guide requires soldering. For more information on soldering, take a look at this guide on How to Solder and Desolder Connections.
Ce dont vous avez besoin
Flip over the Petcube so the rubber bottom faces you.
Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
The next step is to remove the front plates from each other. This is located behind the motherboard and is shown in the pictures.
To do this you will need to remove the highlighted screws using a #1 Phillips head screwdriver.
First, remove the front plastic casing from the circuit board
Next, identify the LED and the foam protector.
Remove the foam protector using thin tweezers and gently pulling upwards.
Finally, use a soldering iron to desolder the LED from the board and solder the new LED in the same place and orientation.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
