Aller au contenu principal
Petcube Play 2 Laser Replacement
Ce dont vous avez besoin
  1. Petcube Play 2 Laser Replacement, Motherboard: étape 1, image 1 de 3 Petcube Play 2 Laser Replacement, Motherboard: étape 1, image 2 de 3 Petcube Play 2 Laser Replacement, Motherboard: étape 1, image 3 de 3
    • Flip over the Petcube so the rubber bottom faces you.
    • Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
  2. Petcube Play 2 Laser Replacement: étape 2, image 1 de 2 Petcube Play 2 Laser Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Laser Replacement: étape 3, image 1 de 2 Petcube Play 2 Laser Replacement: étape 3, image 2 de 2
    • Use an opening pick or spudger to pry off the glass front panel.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Laser Replacement: étape 4, image 1 de 3 Petcube Play 2 Laser Replacement: étape 4, image 2 de 3 Petcube Play 2 Laser Replacement: étape 4, image 3 de 3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Laser Replacement: étape 5, image 1 de 3 Petcube Play 2 Laser Replacement: étape 5, image 2 de 3 Petcube Play 2 Laser Replacement: étape 5, image 3 de 3
    • Once the internal assembly is removed, you should see a brass cylinder in the top left of the front face of the cube. At the top of that cylinder is a hole that leads down to a screw.
    • Remove it using a Phillips head size #1 screwdriver.
  6. Petcube Play 2 Laser Replacement: étape 6, image 1 de 3 Petcube Play 2 Laser Replacement: étape 6, image 2 de 3 Petcube Play 2 Laser Replacement: étape 6, image 3 de 3
    • Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
    • Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Laser Replacement: étape 7, image 1 de 3 Petcube Play 2 Laser Replacement: étape 7, image 2 de 3 Petcube Play 2 Laser Replacement: étape 7, image 3 de 3
    • Disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Laser Replacement: étape 8, image 1 de 3 Petcube Play 2 Laser Replacement: étape 8, image 2 de 3 Petcube Play 2 Laser Replacement: étape 8, image 3 de 3
    • Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
    • Carefully release the three tabs and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 Laser Replacement, Laser: étape 9, image 1 de 3 Petcube Play 2 Laser Replacement, Laser: étape 9, image 2 de 3 Petcube Play 2 Laser Replacement, Laser: étape 9, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the seven screws from the part of the cube where the motherboard was removed.
    • Remove the plastic front to expose the board with the laser.
  10. Petcube Play 2 Laser Replacement: étape 10, image 1 de 2 Petcube Play 2 Laser Replacement: étape 10, image 2 de 2
    • Once the motherboard is off and the plastic is removed, the internal circuit board is visible.
    • Remove the board from the plastic and locate the lasers ribbon connector.
  11. Petcube Play 2 Laser Replacement: étape 11, image 1 de 2 Petcube Play 2 Laser Replacement: étape 11, image 2 de 2
    • Use a spudger, or a clean fingernail to flip up the locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket and remove the laser assembly from the board.
    • Be gentle and patient as the ribbon cable is delicate and can break easily.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Christopher Pereira
Membre depuis le 03/18/24
181 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Konn Spring 2024 Membre de l'équipe UMass Dartmouth, Team 1-5, Konn Spring 2024
UMASSD-KONN-S24S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 39
Total : 106
