Aller au contenu principal
Petcube Play 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Petcube Play 2 Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Petcube Play 2 Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Petcube Play 2 Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Flip over the Petcube so the rubber bottom faces you.
    • Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
  2. Petcube Play 2 Motherboard Replacement: étape 2, image 1 de 2 Petcube Play 2 Motherboard Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Motherboard Replacement: étape 3, image 1 de 2 Petcube Play 2 Motherboard Replacement: étape 3, image 2 de 2
    • Use an opening pick or spudger to pry off the glass front panel.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Motherboard Replacement: étape 4, image 1 de 3 Petcube Play 2 Motherboard Replacement: étape 4, image 2 de 3 Petcube Play 2 Motherboard Replacement: étape 4, image 3 de 3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Motherboard Replacement: étape 5, image 1 de 3 Petcube Play 2 Motherboard Replacement: étape 5, image 2 de 3 Petcube Play 2 Motherboard Replacement: étape 5, image 3 de 3
    • Once the internal assembly is removed, you should see a brass cylinder in the top left of the front face of the cube. At the top of that cylinder is a hole that leads down to a screw.
    • Remove it using a Phillips head size #1 screwdriver.
  6. Petcube Play 2 Motherboard Replacement: étape 6, image 1 de 3 Petcube Play 2 Motherboard Replacement: étape 6, image 2 de 3 Petcube Play 2 Motherboard Replacement: étape 6, image 3 de 3
    • Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
    • Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Motherboard Replacement: étape 7, image 1 de 3 Petcube Play 2 Motherboard Replacement: étape 7, image 2 de 3 Petcube Play 2 Motherboard Replacement: étape 7, image 3 de 3
    • Disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Motherboard Replacement: étape 8, image 1 de 3 Petcube Play 2 Motherboard Replacement: étape 8, image 2 de 3 Petcube Play 2 Motherboard Replacement: étape 8, image 3 de 3
    • Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
    • Carefully release the three tabs and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jacob Branco
Membre depuis le 03/18/24
291 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Konn Spring 2024 Membre de l'équipe UMass Dartmouth, Team 1-5, Konn Spring 2024
UMASSD-KONN-S24S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 21
Total : 106
