Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Porter-Cable PCE211 Fan Replacement
Ce dont vous avez besoin
  1. Porter-Cable PCE211 Fan Replacement, Gearcase: étape 1, image 1 de 2 Porter-Cable PCE211 Fan Replacement, Gearcase: étape 1, image 2 de 2
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
    Demander à FixBot
    Ajouter un commentaire
  2. Porter-Cable PCE211 Fan Replacement: étape 2, image 1 de 3 Porter-Cable PCE211 Fan Replacement: étape 2, image 2 de 3 Porter-Cable PCE211 Fan Replacement: étape 2, image 3 de 3
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
    Demander à FixBot
  3. Porter-Cable PCE211 Fan Replacement, Anvil: étape 3, image 1 de 3 Porter-Cable PCE211 Fan Replacement, Anvil: étape 3, image 2 de 3 Porter-Cable PCE211 Fan Replacement, Anvil: étape 3, image 3 de 3
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
    Demander à FixBot
  4. Porter-Cable PCE211 Fan Replacement, Motor: étape 4, image 1 de 3 Porter-Cable PCE211 Fan Replacement, Motor: étape 4, image 2 de 3 Porter-Cable PCE211 Fan Replacement, Motor: étape 4, image 3 de 3
    • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
    • Pull the motor out with your hands.
    Demander à FixBot
  5. Porter-Cable PCE211 Fan Replacement: étape 5, image 1 de 3 Porter-Cable PCE211 Fan Replacement: étape 5, image 2 de 3 Porter-Cable PCE211 Fan Replacement: étape 5, image 3 de 3
    • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
    Demander à FixBot
  6. Porter-Cable PCE211 Fan Replacement, Rear Housing: étape 6, image 1 de 2 Porter-Cable PCE211 Fan Replacement, Rear Housing: étape 6, image 2 de 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
    Demander à FixBot
  7. Porter-Cable PCE211 Fan Replacement: étape 7, image 1 de 2 Porter-Cable PCE211 Fan Replacement: étape 7, image 2 de 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
    Demander à FixBot
  8. Porter-Cable PCE211 Fan Replacement, Grip: étape 8, image 1 de 2 Porter-Cable PCE211 Fan Replacement, Grip: étape 8, image 2 de 2
    • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
    Demander à FixBot
  9. Porter-Cable PCE211 Fan Replacement: étape 9, image 1 de 2 Porter-Cable PCE211 Fan Replacement: étape 9, image 2 de 2
    • Pull the grip from the body of the impact wrench.
    Demander à FixBot
  10. Porter-Cable PCE211 Fan Replacement, Fan: étape 10, image 1 de 2 Porter-Cable PCE211 Fan Replacement, Fan: étape 10, image 2 de 2
    • Lift the hammer block (which is attached to the fan) out of the case.
    • It is a little heavy so be careful when lifting it out.
    Demander à FixBot
  11. Porter-Cable PCE211 Fan Replacement: étape 11, image 1 de 2 Porter-Cable PCE211 Fan Replacement: étape 11, image 2 de 2
    • If you're doing maintenance and the fan isn't damage, use a microfiber cloth to clean the fan.
    • Wipe well until there's no residue or oil lubricant.
    Demander à FixBot
Layla Berry
Membre depuis le 09/19/22
678 Réputation
7 tutoriels rédigés
Équipe
Austin Community College, Team 13-1, Watkins Fall 2022 Membre de l'équipe Austin Community College, Team 13-1, Watkins Fall 2022
AUSTINCC-WATKINS-F22S13G1
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 26
Total : 408
