Aller au contenu principal
PowerShot G7 X Mark II Front Cover Replacement
Ce dont vous avez besoin
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: étape 1, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: étape 1, image 2 de 2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: étape 2, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 2, image 2 de 2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: étape 3, image 1 de 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
    the other screw (on the top) must be removed too
    oluc - Réponse
  4. PowerShot G7 X Mark II Front Cover Replacement: étape 4, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 4, image 2 de 2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
    Use a Phillips #000 screwdriver to remove one ~6mm above the button and one 4mm screw bellow the button on the surface of the right face of the camera. Additionally, one 3mm under the USB/HDMI cover.
    Andrew Grasman - Réponse
  5. PowerShot G7 X Mark II Front Cover Replacement: étape 5, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 5, image 2 de 2
    • Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
    • If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
  6. PowerShot G7 X Mark II Front Cover Replacement: étape 6, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
    and unclip the top hat of the pop-up flash, then push the flash back in place.
    This is needed to be able to remove completely the top cover.
    oluc - Réponse
    ~2.6 ish mm and thinner, not like the other 3mm
  7. PowerShot G7 X Mark II Front Cover Replacement: étape 7, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 7, image 2 de 2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 1 de 3 PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 2 de 3 PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 3 de 3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
    Wow I removed the battery before Step 1!!!
    JOHN J GRAY - Réponse
  9. PowerShot G7 X Mark II Front Cover Replacement: étape 9, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 9, image 2 de 2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
    first, detach the ZIF connector
    oluc - Réponse
    be careful when detaching the top cover : there's a small metallic part that is loose and will fall.
    This part is a ~10mm bent metal strip, with a screw hole.
    When in place it holds with the long screw from the battery compartment (step 8)
    oluc - Réponse
    hi can u please help me remove the dial wheel on the upper cover. mine become stuck and i am hoping that you could help me fix it.. thankyouu
    keith. - Réponse
    please do a tutorial on how to remove the dial wheel on upper cover..
    keith. - Réponse
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: étape 10, image 1 de 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
    I got
    - two 4mm screws on the left (golden-ish)
    - one 3mm screw on the right (silver)
    (rather than “two 3mm and one 5mm”)
    oluc - Réponse
  11. PowerShot G7 X Mark II Front Cover Replacement: étape 11, image 1 de 1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: étape 12, image 1 de 1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
    That ZIF connector in step 12 was really hard to detach so I think I broke one of those little holders for it. Is there any replacement ribbon with those holders? What are my options?
    Bartol Filić - Réponse
    actually it's not a ZIF connector, so don't try to pull/push the grey “box”, you'll break it.
    It's a basic connector/socket : just gently pull the ribbon.
    you can see it for example (at 7”20’)
    https://www.youtube.com/watch?v=v0vso3CI...
    oluc - Réponse
2 autres ont terminé cette réparation.
Brandon
Membre depuis le 02/15/17
626 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 12-3, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 membres
4 tutoriels rédigés
2 commentaires
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Réponse
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 36
Total : 4,316
