PowerShot G7 X Mark II Front Cover Replacement
Introduction
Passez à l'étape 1This guide will show you how to replace the Front Panel and Focus Ring of the camera if it is damaged or if the lens has gotten dirt lodged in it.
Ce dont vous avez besoin
Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
Use a Phillips #000 screwdriver to remove one ~6mm above the button and one 4mm screw bellow the button on the surface of the right face of the camera. Additionally, one 3mm under the USB/HDMI cover.
Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
~2.6 ish mm and thinner, not like the other 3mm
Open the battery compartment and remove the battery by flipping the small latch holding it in.
Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
That ZIF connector in step 12 was really hard to detach so I think I broke one of those little holders for it. Is there any replacement ribbon with those holders? What are my options?
actually it's not a ZIF connector, so don't try to pull/push the grey “box”, you'll break it.
It's a basic connector/socket : just gently pull the ribbon.
you can see it for example (at 7”20’)
2 autres ont terminé cette réparation.
2 commentaires
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
